I am trying to implement the 1-Wire protocol to read a DS18B20 temperature sensor on the PocketBeagle. So far I have been able to correctly read the temperature on a BeagleBone Black (BBB) using the following guide:
http://www.bonebrews.com/temperature-monitoring-with-the-ds18b20-on-a-beaglebone-black/
I changed the .dts file below to use the same GPIO port on the BBB (P8.11 - GPIO45) as on the PocketBeagle (P2.33 - GPIO45) on line 19 and added the missing semicolon on line 37. I checked the GPIO offset for both of these pins and they are the same, so it should be the same signal.
- Copyright © 2012 Texas Instruments Incorporated - http://www.ti.com/
