dave higton wrote:
Quoting Koen Kooi<koen@beagleboard.org>:
>> The supported pixclock is>170MHz on beagle
> Where is this specified?
In the omap3 TRM.
> I have always understood that the maximum pixel rate was
> 83 MHz (original BB).
If you use the DSI PLL you get a 173MHz pixclock. Angstrom enabled that as
default in the kernel, and has done that for years now. I have 1080p24
working nicely on a C4.
But 1920 x 1080 x 24 fps is a net rate of 48384000 triads/sec,
isn't it, so even when overheaded for the flyback periods,
it only requires a pixel clock in the ballpark of 50 MHz,
doesn't it?
no, the H and V blanking periods are huge...
1080p24: 1920x1080@24 in 2750x1125 -> 74.25 MHz
Quoting Vladimir Pantelic <vladoman@gmail.com>:
>> In the omap3 TRM.
as
> doesn't it?
OK, but it's still way below 173 MHz. It's even below 83 MHz,
so 1080p24 would still work even if the pixel clock were
limited to the 83 MHz figure that I had in mind, wouldn't it?
It's not a difficult screen mode to achieve.
Dave
Hi Koen:
Could you indicate how I should adjust the file boot.scr for a
resolution of 1680x1050, for a DVI monitor ViewSonic brand
Carlos
