Hi forks,
I found an interesting development board has a ARM 1.4Ghz Quad-core processor with 6 USB 2.0 hosts and an Ethernet.
It seems to be the cheapest Quad-core board available today…
Source :
Hi forks,
Source :
I would not consider Samsung as a development board. Same as for Raspberry. It’s only a toy to play with. Nothing serious… You can only develop software on this board and no further hardware development. Had their first Hardkernel toy in form of a small tablet. Absolutely useless and so slow! To my luck I could sell in a few days after purchasing
Actually it seems amazing on the video !!!
Have anyone tried it ? How is performance ?
2012/7/11 Maxim Podbereznyy <lisarden@gmail.com>
I have to agree. The specs and the video seem to say it's a good board I could use to incorporate as part of a Software Defined Radio but I would have to read a bit more especially on the GPU to see if existing software could use it for some of the number crunching.
The Pandaboard does a very good job with 2 CPU's so this looks as though it could adequately fit the bill.
Regards
Sid.
Maxim why do you say this or a raspPi isn’t a dev board? Is it because they aren’t open with the design specs, such that you couldn’t customize your own fabbed boards?
software could use it for some of the number crunching.The Pandaboard does a very good job with 2 CPU's so this looks as though
it could adequately fit the bill.I find the I/O limiting the Pandaboard. SD cards are to damn slow so I
use USB Harddrives, which give it quite a boost.
I use a Class 10 SD card with the Pandaboard together with a 60GB hard drive.
I followed a write-up on how to use rootfs from a USB HD but it didn't work out and I didn't look further.
Is there some ARM-Board with sata-ports, which you can put in a acutal case which some
sata drives? Maybe in the itx-factor?
There are these boards but they seem to be all single core.
http://www.embeddedarm.com/products/board-detail.php?product=TS-7800 (Expensive)
This one is quad core but no price and no date when it'll be available.
Perhaps the ODROID-X ($129) with a large Class 10 SD card and a HD would be a good bet, quad core 1.4GHz and 1G memory.
http://www.hardkernel.com/renewal_2011/products/prdt_info.php?g_code=G133999328931&tab_idx=2
73 ... Sid.
ODROID-PC has a native SATA port.
Dual-core Cortex-A9 1.2Ghz with 1GB RAM.
It looks okay for you. But it is too expensive… $350!
http://www.hardkernel.com/renewal_2011/products/prdt_info.php?g_code=G132342040298
2012/7/31 Sid Boyce <sboyce@blueyonder.co.uk>
Alex <alex@zengers.de> [2012-07-30 23:36:36]:
which some sata drives? Maybe in the itx-factor?
-- ynezz
Very expensive when you consider what the $129 Quad-core 1.4 GHz and 1GB memory ODROID-X has to offer.
73 ... Sid.
