2.6.24rc4 bootlog and stability problems
Steve said booting had become more reliable for him, so I tried latest
git and was pleasantly surprised.
There as a ton of warnings about clocks, but I don't know how serious
those are.
Linux version 2.6.26-rc4-omap1 (koen@lieve) (gcc version 4.2.4) #2
PREEMPT Sun Jun 1 11:46:42 CEST 2008
CPU: ARMv7 Processor [411fc082] revision 2 (ARMv7), cr=00c5387f
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
On node 0 totalpages: 32768
  DMA zone: 256 pages used for memmap
  DMA zone: 0 pages reserved
  DMA zone: 32512 pages, LIFO batch:7
  Normal zone: 0 pages used for memmap
  Movable zone: 0 pages used for memmap
OMAP3430 ES2.0
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
CPU0: D VIPT write-through cache
CPU0: cache: 768 bytes, associativity 1, 8 byte lines, 64 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
32512
Kernel command line: root=/dev/mmcblk0p2 rootdelay=2
console=ttyS2,115200n8 noinitrd rootfstype=ext3 ip=off
Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
GPMC revision 5.0
IRQ: Found an INTC at 0x48200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP34xx GPIO hardware version 2.5
PID hash table entries: 512 (order: 9, 2048 bytes)
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB 0MB = 128MB total
Memory: 125312KB available (3992K code, 357K data, 148K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1,
Nodes=1
Calibrating delay loop... 499.92 BogoMIPS (lpj=1949696)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 324 bytes
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
OMAP3 L2 cache enabled
OMAP DMA hardware revision 4.0
USB: No board-specific platform config found
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz
TWL4030: TRY attach Slave TWL4030-ID0 on Adapter OMAP I2C adapter [1]
TWL4030: TRY attach Slave TWL4030-ID1 on Adapter OMAP I2C adapter [1]
TWL4030: TRY attach Slave TWL4030-ID2 on Adapter OMAP I2C adapter [1]
TWL4030: TRY attach Slave TWL4030-ID3 on Adapter OMAP I2C adapter [1]
Initialized TWL4030 USB module
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc: ConfigData=0x55 (UTMI-16, dyn FIFOs, bulk split (X), HB-ISO
Rx (X))
musb_hdrc: MHDRC RTL version 1.400
musb_hdrc: setup fifo_mode 4
musb_hdrc: 29/15 max ep, 7232/16384 memory
musb_hdrc: hw_ep 0shared, max 64
musb_hdrc: hw_ep 1tx, max 512
musb_hdrc: hw_ep 1rx, max 512
musb_hdrc: hw_ep 2tx, max 512
musb_hdrc: hw_ep 2rx, max 512
musb_hdrc: hw_ep 3tx, max 512
musb_hdrc: hw_ep 3rx, max 512
musb_hdrc: hw_ep 4tx, max 512
musb_hdrc: hw_ep 4rx, max 512
musb_hdrc: hw_ep 5tx, max 512
musb_hdrc: hw_ep 5rx, max 512
musb_hdrc: hw_ep 6tx, max 512
musb_hdrc: hw_ep 6rx, max 512
musb_hdrc: hw_ep 7tx, max 512
musb_hdrc: hw_ep 7rx, max 512
musb_hdrc: USB OTG mode controller at c8800000 using DMA, IRQ 92
Bluetooth: Core ver 2.11
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
NET: Registered protocol family 2
Switched to high resolution mode on CPU 0
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 244 for ipc namespace c042be1c
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
omapfb: configured for panel omap3beagle
Clock dss_ick didn't enable in 100000 tries
Clock dss1_alwon_fck didn't enable in 100000 tries
omapfb: DISPC version 3.0 initialized
Console: switching to mono frame buffer device 128x48
omapfb: Framebuffer initialized. Total vram 2359296 planes 1
omapfb: Pixclock 48000 kHz hfreq 44.7 kHz vfreq 57.7 Hz
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing
enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
i2c /dev entries driver
i2c_omap i2c_omap.2: controller timed out
TWL4030 GPIO Demux: IRQ Range 384 to 402, Initialization Success
input: triton2-pwrbutton as /class/input/input0
triton2 power button driver initialized
Driver 'sd' needs updating - please use bus_type methods
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB
1,8V 16-bit)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on "omap2-nand":
0x00000000-0x00080000 : "X-Loader"
0x00080000-0x00260000 : "U-Boot"
0x00260000-0x00280000 : "U-Boot Env"
0x00280000-0x00680000 : "Kernel"
0x00680000-0x10000000 : "File System"
TI TSC2102 driver initializing
usbmon: debugfs is not available
Clock usbhost_48m_fck didn't enable in 100000 tries
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ether gadget: using random self ethernet address
ether gadget: using random host ethernet address
usb0: Ethernet Gadget, version: May Day 2005
usb0: using musb_hdrc, OUT ep1out IN ep1in STATUS ep2in
usb0: MAC 3e:5c:80:4c:66:2c
usb0: HOST MAC aa:db:a5:6c:b7:c0
usb0: RNDIS ready
musb_hdrc musb_hdrc.0: MUSB HDRC host driver
musb_hdrc musb_hdrc.0: new USB bus registered, assigned bus number 2
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mice: PS/2 mouse device common for all mice
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
Bluetooth: HCI USB driver ver 2.9
usbcore: registered new interface driver hci_usb
Bluetooth: Broadcom Blutonium firmware driver ver 1.1
usbcore: registered new interface driver bcm203x
Bluetooth: Digianswer Bluetooth USB driver ver 0.9
usbcore: registered new interface driver bpa10x
Bluetooth: Generic Bluetooth SDIO driver ver 0.1
Registered led device: beagleboard::led0
Registered led device: beagleboard::led1
usb 2-1: new high speed USB device using musb_hdrc and address 2
mmc0: host does not support reading read-only switch. assuming write-
enable.
mmc0: new SD card at address e624
mmcblk0: mmc0:e624 SD01G 992000KiB
mmcblk0: p1 p2
usb 2-1: device v050d p0231 is not supported
usb 2-1: configuration #1 chosen from 1 choice
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.16.
ASoC version 0.13.2
ALSA device list:
  No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Bluetooth: L2CAP ver 2.9
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO (Voice Link) ver 0.5
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
Bluetooth: BNEP (Ethernet Emulation) ver 1.2
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
At present we have all clocks enabled in u-boot, to get diags and logo working in u-boot, if we have to get rid of these warnings then it might be good to check disabling the all clocks on in u-boot and allow kernel to handle clocks. But for this to work we have to also disable logo and audio functionality.
Will check if other boards (EVM / SDP) are getting these messages.
Khasim
functionality.
With CONFIG_OMAP_RESET_CLOCKS=y in the kernel I get:
Linux version 2.6.26-rc4-omap1 (koen@lieve) (gcc version 4.2.4) #1
PREEMPT Mon Jun 2 14:17:20 CEST 2008
OMAP3430 ES2.0
32512
GPMC revision 5.0
Memory: 125312KB available (3996K code, 357K data, 148K init)
Nodes=1
Found NAND on CS0
Rx (X))
TCP reno registered
msgmni has been set to 244 for ipc namespace c042bebc
enabled
brd: module loaded
loop: module loaded
1,8V 16-bit)
usb0: MAC 56:d2:ff:3f:d0:88
usb0: HOST MAC 8a:f9:07:12:7c:5a
usb0: RNDIS ready
enable.
mmcblk0: p1 p2
ASoC version 0.13.2
ALSA device list:
