2 BBB do not boot after opkg update and upgrade
This happened to me too, I hooked up an FTDI serial cable to the serial debug port and rebooted; it fails to find the “uImage” kernel file and thus lands you at the uBoot command prompt.
From this force it to boot uImage-3.8.6 using the following uboot commands:
env set bootfile uImage-3.8.6
boot
After it boots, run this to force-upgrade the kernel:
opkg --force-overwrite install kernel-image-3.8.8
After doing that my BBB boots without a hitch.
As of this morning opkg upgrade is bringing in 3.8.10 modules. This means we need to use the corresponding 3.8.10 kernel image right? I checked in the modules directory - only directories for 3.8.6 and 3.8.10 were present.
K
