Once again, no reboot after opkg upgrade
My BBB was working fine in 3.8.8, but I had a problem in installing easy_install. As I saw that the kernel has
already upgraded to 3.8.11, I tried again the upgrade through opkg update and opkg upgrade.
Things went fine, but maybe I did an error in asking for opkg upgrade again.
I then got
root@beaglebone:~# opkg upgrade
Upgrading kernel-module-openvswitch on root from 3.8.8-r23a.0 to 3.8.11-r23a.0…
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a-vfp-neon/machine/beaglebone/kernel-module-openvswitch_3.8.11-r23a.0_beaglebone.ipk.
Removing obsolete file /lib/modules/3.8.8/kernel/net/openvswitch/openvswitch.ko.
Upgrading kernel-module-bone-iio-helper on root from 3.8.8-r23a.0 to 3.8.10-r23a.1…
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a-vfp-neon/machine/beaglebone/kernel-module-bone-iio-helper_3.8.10-r23a.1_beaglebone.ipk.
Removing obsolete file /lib/modules/3.8.8/kernel/drivers/misc/cape/beaglebone/bone-iio-helper.ko.
Upgrading kernel-modules on root from 3.8.8-r23a.0 to 3.8.11-r23a.0…
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a-vfp-neon/machine/beaglebone/kernel-modules_3.8.11-r23a.0_beaglebone.ipk.
Installing kernel-devicetrees (3.8.11-r23a.0) to root…
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.12/ipk/eglibc/armv7a-vfp-neon/machine/beaglebone/kernel-devicetrees_3.8.11-r23a.0_beaglebone.ipk.
Configuring kernel-module-openvswitch.
Configuring kernel-module-bone-iio-helper.
Configuring bonescript.
Job for bonescript.socket failed. See ‘systemctl status bonescript.socket’ and ‘journalctl -xn’ for details.
WARNING: could not open /lib/modules/3.8.10/modules.order: No such file or directory
WARNING: could not open /lib/modules/3.8.10/modules.builtin: No such file or directory
WARNING: could not open /lib/modules/3.8.11/modules.order: No such file or directory
WARNING: could not open /lib/modules/3.8.11/modules.builtin: No such file or directory
Collected errors:
- check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/am335x-evmsk.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap3-beagle-xm.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/am335x-boneblack.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap3-tobi.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/am335x-bone.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap5-evm.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap4-panda.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap4-var-som.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/am335x-evm.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap3-beagle.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap3-evm.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap4-sdp.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap4-panda-es.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap4-panda-a4.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/am335x-tester.dtb
But that file is already provided by package * kernel-image-3.8.8 - check_data_file_clashes: Package kernel-devicetrees wants to install file /boot/omap2420-h4.dtb
But that file is already provided by package * kernel-image-3.8.8 - pkg_run_script: package “bonescript” postinst script returned status 1.
- opkg_configure: bonescript.postinst returned 1.
and the machine do not reboot again… Grrr !
Hope this will soon stabilize to a solid system …
Jacques
