2013.05.08 image
I also saw all those messages in the kernel log but only when I had the USB connected to another computer. Once I disconnected it the RNDIS driver was unloaded and the kernel spam stopped.
I asked about it several days ago but no one spoke up with any suggestions for how to disable all that noise.
I plugged the BBB into a AC USB adapter instead of using my PC to power the BBB and you are right, the messages stopped :slight_smile: Now I can see the messages that verified that my virtual capes for enabling two uarts were installed.
Also it might be my imagination but I think the performance in the console windows appears to be a lot faster.
Thanks again
Kurt
P.S. - Not sure if what dmesg | tail on this is what is expected, as it shows process terminated by segmentation fault?
root@beaglebone ~ # dmesg | tail
[ 5.891212] libphy: PHY 4a101000.mdio:01 not found
[ 5.896267] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 6.029710] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.643813] usb0: eth_open
[ 6.644024] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.967020] libphy: 4a101000.mdio:00 - Link is Up - 100/Full
[ 8.967085] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.462749] systemd-udevd[88]: worker [156] terminated by signal 11 (Segmentation fault)
[ 10.480195] systemd-udevd[88]: worker [156] failed while handling ‘/devices/ocp.2/47400000.usb/musb-hdrc.0.auto/gadget/net/usb0’
[ 28.493224] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=0
