Ok, so as a note to all those out there . . . to resize one of the 2G images to any sdcard size, The below “guide” will work. However, this is only tested on a single partition image, and if using a 2 partition image, you need to use the appropriate partition. USE AT YOUR OWN RISK One single typo can render your file system and / or the boot loader inoperable . . .
These steps were taken on an i386 Debian install ( PC ) with the sdcard listed at /dev/sdc:
william@eee-pc:~$ sudo fdisk /dev/sdc
Command (m for help): p
Disk /dev/sdc: 3963 MB, 3963617280 bytes
184 heads, 31 sectors/track, 1357 cylinders, total 7741440 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sdc1 * 2048 3481599 1739776 83 Linux
Command (m for help): d
Selected partition 1
Command (m for help): n
Partition type:
p primary (0 primary, 0 extended, 4 free)
e extended
Select (default p): p
Partition number (1-4, default 1): 1
First sector (2048-7741439, default 2048): 2048
Last sector, +sectors or +size{K,M,G} (2048-7741439, default 7741439):
Using default value 7741439
36 heads, 27 sectors/track, 7964 cylinders, total 7741440 sectors
/dev/sdc1 2048 7741439 3869696 83 Linux
Command (m for help): a
Partition number (1-4): 1
/dev/sdc1 * 2048 7741439 3869696 83 Linux
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
william@eee-pc:~$
william@eee-pc:~$ sudo e2fsck -f /dev/sdc1
e2fsck 1.42.5 (29-Jul-2012)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
rootfs: 14430/108864 files (0.1% non-contiguous), 74875/434944 blocks
william@eee-pc:~$ sudo resize2fs /dev/sdc1
resize2fs 1.42.5 (29-Jul-2012)
Resizing the filesystem on /dev/sdc1 to 967424 (4k) blocks.
The filesystem on /dev/sdc1 is now 967424 blocks long.
Then on the Beagelbone Black once booted . . .
root@beaglebone:~# df -h /
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p1 3.7G 235M 3.2G 7% /
root@beaglebone:~# uname -a
Linux beaglebone 3.14.26-ti-r39 #1 SMP PREEMPT Mon Dec 8 04:56:09 UTC 2014 armv7 l GNU/Linux
root@beaglebone:~# cat /ID.txt
BeagleBoard.org BeagleBone Debian Image 2014-11-19
For those who may be wondering. This image was pulled off the recommended links for “official” testing images. The initial partition size is 2G ( minimal command line image ). This is an “all-in-one” partition where the boot loader files are in a “1M hole” at the beginning of the sdcard. Initial kernel was 3.8.13-bone67 then upgraded to the latest 3.14.x TI kernel using APT.
root@beaglebone:~# ls /boot/
SOC.sh config-3.8.13-bone67 uEnv.txt
System.map-3.14.26-ti-r39 dtbs uboot
System.map-3.8.13-bone67 initrd.img-3.14.26-ti-r39 vmlinuz-3.14.26-ti-r39
config-3.14.26-ti-r39 initrd.img-3.8.13-bone67 vmlinuz-3.8.13-bone67
I actually made a mistake, by forgetting to check / update the partition to active ( * boot ) by using “a” while in fdisk. I then inserted the sdcard into the Beaglebone black. Only to be greeted by 3 solidly lit USR LEDs. After which, I put the sdcard back into my PC, started fdisk again, and marked the partition appropriately. Of course then the board booted up fine.
