2x14 expansion header with sufficient height to clear USB connectors?
Hi all,
I have an FPGA daughterboard designed for the Pandaboard, but there
aren't many hardware people in that forum, so I thought I'd try my
question here. (Both boards use 2x14 expansion-headers---we just have
two of them.)
I need to find a 2x14 (0.1" pitch) header combo with non-standard
height---enough to clear at least a double-USB connector, and perhaps
enough to clear a double-USB-plus-Ethernet connector like the one on
Panda. This requires a board-to-board spacing of at least 1 to 1.5
inches.
My board can mount underneath the Panda, but as it sports a dual-USB
connector of its own, I have a the same problem there. It's too late
for me to change the design to flip one of the boards over.
I haven't had much luck searching for tall headers on Digikey. Anyone
run into this problem before?
Mark
Try samtec. They sell 0.1" headers in a ton of configurations and they do small orders. I've gotten long male 0.1" headers form them before.
http://www.samtec.com/standardboardtoboard/100_pitch_square.aspx
-Scott
Thanks! Plenty of good choices there. Now to decide which one...
Mark
You can refer to the BeagleBoard-xM System Reference Manual for part numbers. The second bullet under Getting Started" http://beagleboard.org/
Hi Gerald,
I should have thought more carefully about this prior to layout. The
Pandaboard ships without the expansion headers populated, so one can
choose which side they are on. I probably made the wrong choice,
laying out my right-side-up board to either sit above or below the
right-side-up Pandaboard. The upside-down approach would have reduced
the needed stack height considerably. But I think it will still be ok
with longer headers.
Mark
OK. I have nothing to do with Panda, so you most likely will need to work with them to determine any other issues that could arise.
