For people who want to test the latest kernel, give the following a try:
http://dominion.thruhere.net/koen/angstrom/beagleboard/3.0/uImage-3.0-r101e-beagleboard-20110722071748.bin
http://dominion.thruhere.net/koen/angstrom/beagleboard/3.0/modules-3.0.0+-r101e-beagleboard.tgz
You can rebuild it using the meta-ti metadata: http://git.angstrom-distribution.org/cgi-bin/cgit.cgi/meta-texasinstruments/tree/README or manually with the instructions below.
The list of patches applied on top of Linus' release:
Andy Green (6):
I2C: OMAP2+: Set hwmod flags to only allow 16-bit accesses to i2c
I2C: OMAP2+: increase omap_i2c_dev_attr flags from u8 to u32
I2C: OMAP2+: Introduce I2C IP versioning constants
I2C: OMAP1/OMAP2+: create omap I2C functionality flags for each cpu_... test
I2C: OMAP2+: Tag all OMAP2+ hwmod defintions with I2C IP revision
I2C: OMAP2+: add correct functionality flags to all omap2plus i2c dev_attr
Arnd Bergmann (1):
omap2+: fix build regression
Avinash.H.M (1):
OMAP: hwmod: fix the i2c-reset timeout during bootup
Benoit Cousson (36):
OMAP2+: hwmod: Fix smart-standby + wakeup support
OMAP4: hwmod data: Add MSTANDBY_SMART_WKUP flag
OMAP2+: hwmod: Do not write the enawakeup bit if SYSC_HAS_ENAWAKEUP is not set
OMAP2+: hwmod: Remove _populate_mpu_rt_base warning
OMAP2+: hwmod: Fix the HW reset management
OMAP: hwmod: Add warnings if enable failed
OMAP: hwmod: Move pr_debug to improve the readability
OMAP4: hwmod data: Fix L3 interconnect data order and alignement
OMAP4: hwmod data: Remove un-needed parens
OMAP4: hwmod data: Fix bad alignement
OMAP4: hwmod data: Align interconnect format with regular modules
OMAP4: clock data: Add sddiv to USB DPLL
OMAP4: clock data: Remove usb_host_fs clkdev with NULL dev
OMAP4: clock data: Re-order some clock nodes and structure fields
OMAP4: clock data: Fix max mult and div for USB DPLL
OMAP4: prcm: Fix errors in few defines name
OMAP4: prm: Remove wrong clockdomain offsets
OMAP4: powerdomain data: Fix indentation
OMAP4: cm: Remove RESTORE macros to avoid access from SW
OMAP4: prcm_mpu: Fix indent in few macros
OMAP4: clockdomain data: Fix data order and wrong name
OMAP4: powerdomain data: Fix core mem states and missing cefuse flag
OMAP: omap_device: Create clkdev entry for hwmod main_clk
OMAP4: hwmod data: Add clock domain attribute
OMAP2+: hwmod: Init clkdm field at boot time
OMAP4: hwmod: Replace CLKCTRL absolute address with offset macros
OMAP: hwmod: Wait the idle status to be disabled
OMAP4: hwmod: Replace RSTCTRL absolute address with offset macros
OMAP4: prm: Replace warm reset API with the offset based version
OMAP4: prm: Remove deprecated functions
OMAP4: hwmod data: Add PRM context register offset
OMAP4: hwmod data: Add modulemode entry in omap_hwmod structure
OMAP4: cm: Add two new APIs for modulemode control
OMAP4: hwmod: Introduce the module control in hwmod control
OMAP2+: clockdomain: Add 2 APIs to control clockdomain from hwmod framework
OMAP4: powerdomain data: add voltage domains
Colin Cross (1):
OMAP2+: cpufreq: notify even with bad boot frequency
Fernandes, Joel A (1):
OMAP3: beagle: add support for beagleboard xM revision C
Grazvydas Ignotas (1):
omap: cleanup NAND platform data
Jarkko Nikula (5):
omap: mcbsp: Drop SPI mode support
omap: mcbsp: Drop in-driver transfer support
omap: mcbsp: Remove rx_/tx_word_length variables
omap: mcbsp: Remove port number enums
OMAP2PLUS: cpufreq: Fix typo when attempting to set mpu_clk for OMAP4
Jean Pihet (1):
OMAP PM: remove OMAP_PM_NONE config option
Jon Hunter (3):
OMAP4: clock data: Remove McASP2, McASP3 and MMC6 clocks
OMAP4: clock data: Remove UNIPRO clock nodes
OMAP: Add debugfs node to show the summary of all clocks
Keerthy (1):
Enabling Hwmon driver for twl4030-madc
Kevin Hilman (50):
OMAP: omap_device: replace _find_by_pdev() with to_omap_device()
OMAP2+: hwmod: remove unused voltagedomain pointer
OMAP2+: voltage: move PRCM mod offets into VC/VP structures
OMAP2+: voltage: move prm_irqst_reg from VP into voltage domain
OMAP2+: voltage: start towards a new voltagedomain layer
OMAP3: voltage: rename "mpu" voltagedomain to "mpu_iva"
OMAP3: voltagedomain data: add wakeup domain
OMAP3+: voltage: add scalable flag to voltagedomain
OMAP2+: powerdomain: add voltagedomain to struct powerdomain
OMAP2: add voltage domains and connect to powerdomains
OMAP3: powerdomain data: add voltage domains
OMAP2+: powerdomain: add voltage domain lookup during register
OMAP2+: voltage: keep track of powerdomains in each voltagedomain
OMAP2+: voltage: split voltage controller (VC) code into dedicated layer
OMAP2+: voltage: move VC into struct voltagedomain, misc. renames
OMAP2+: voltage: enable VC bypass scale method when VC is initialized
OMAP2+: voltage: split out voltage processor (VP) code into new layer
OMAP2+: VC: support PMICs with separate voltage and command registers
OMAP2+: add PRM VP functions for checking/clearing VP TX done status
OMAP3+ VP: replace transaction done check/clear with VP ops
OMAP2+: PRM: add register access functions for VC/VP
OMAP3+: voltage: convert to PRM register access functions
OMAP3+: VC: cleanup i2c slave address configuration
OMAP3+: VC: cleanup PMIC register address configuration
OMAP3+: VC bypass: use fields from VC struct instead of PMIC info
OMAP3+: VC: cleanup voltage setup time configuration
OMAP3+: VC: move on/onlp/ret/off command configuration into common init
OMAP3+: VC: abstract out channel configuration
OMAP3+: voltage domain: move PMIC struct from vdd_info into struct voltagedomain
OMAP3+: VC: make I2C config programmable with PMIC-specific settings
OMAP3+: PM: VC: handle mutant channel config for OMAP4 MPU channel
OMAP3+: VC: use last nominal voltage setting to get current_vsel
OMAP3+: VP: cleanup: move VP instance into voltdm, misc. renames
OMAP3+: voltage: remove unneeded debugfs interface
OMAP3+: VP: struct omap_vp_common: replace shift with __ffs(mask)
OMAP3+: VP: move SoC-specific sys clock rate retreival late init
OMAP3+: VP: move timing calculation/config into VP init
OMAP3+: VP: create VP helper function for updating error gain
OMAP3+: VP: remove omap_vp_runtime_data
OMAP3+: VP: move voltage scale function pointer into struct voltagedomain
OMAP3+: VP: update_errorgain(): return error if VP
OMAP3+: VP: remove unused omap_vp_get_curr_volt()
OMAP3+: VP: combine setting init voltage into common function
OMAP3+: voltage: rename scale and reset functions using voltdm_ prefix
OMAP3+: voltage: move/rename curr_volt from vdd_info into struct voltagedomain
OMAP3+: voltdm: final removal of omap_vdd_info
OMAP3+: voltage: rename omap_voltage_get_nom_volt -> voltdm_get_voltage
OMAP3+: voltage: update nominal voltage in voltdm_scale() not VC post-scale
OMAP: CPUfreq: ensure policy is fully initialized
cpufreq: fixup after new OPP layer merged
Koen Kooi (3):
UNFINISHED: OMAP3: beagle: add support for expansionboards
HACK: OMAP3: beagle: switch to GPTIMER1
OMAP3: beagle: HACK! add in 1GHz OPP
Miguel Vadillo (1):
OMAP2+: hwmod: Enable module in shutdown to access sysconfig
Mike Turquette (6):
OMAP3630: PRM: add ABB PRM register definitions
OMAP3+: ABB: Adaptive Body-Bias structures & data
OMAP3+: OPP: add ABB data to voltage tables
OMAP3+: Voltage: add ABB data to voltage domains
OMAP3+: ABB: initialization & transition functions
OMAP3+: Voltage: add ABB to voltage scaling
Nishanth Menon (16):
OMAP3+: SR: make notify independent of class
OMAP3+: SR: disable interrupt by default
OMAP3+: SR: enable/disable SR only on need
OMAP3+: SR: fix cosmetic indentation
OMAP4: PM: TWL6030: fix uv to voltage for >0x39
OMAP4: PM: TWL6030: address 0V conversions
OMAP4: PM: TWL6030: add cmd register
PM: OPP: introduce function to free cpufreq table
OMAP2+: cpufreq: move clk name decision to init
OMAP2+: cpufreq: deny initialization if no mpudev
OMAP2+: cpufreq: dont support !freq_table
OMAP2+: cpufreq: only supports OPP library
OMAP2+: cpufreq: put clk if cpu_init failed
OMAP2+: cpufreq: fix freq_table leak
OMAP3+: PM: VP: generalize PRM interrupt helpers
OMAP3+: PRM: add tranxdone IRQ handlers for ABB
Oleg Drokin (2):
cleanup regulator supply definitions in mach-omap2
Remove old-style supply.dev assignments common in hsmmc init
Patrick Titiano (2):
OMAP4: PM: TWL6030: fix voltage conversion formula
OMAP4: PM: TWL6030: fix ON/RET/OFF voltages
Paul Walmsley (10):
OMAP: dmtimer: add missing include
omap_hwmod: use a null structure record to terminate omap_hwmod_addr_space arrays
omap_hwmod: share identical omap_hwmod_addr_space arrays
omap_hwmod: use a terminator record with omap_hwmod_mpu_irqs arrays
omap_hwmod: share identical omap_hwmod_mpu_irqs arrays
omap_hwmod: use a terminator record with omap_hwmod_dma_info arrays
omap_hwmod: share identical omap_hwmod_dma_info arrays
omap_hwmod: share identical omap_hwmod_class, omap_hwmod_class_sysconfig arrays
OMAP2+: clockdomain: add clkdm_in_hwsup()
OMAP2+: clock: allow per-SoC clock init code to prevent clockdomain calls from clock code
Peter 'p2' De Schrijver (1):
OMAP: CPUfreq: ensure driver initializes after cpufreq framework and governors
Peter Ujfalusi (5):
omap: board-omap3evm: Fix compilation error
OMAP: New twl-common for common TWL configuration
OMAP4: Move common twl6030 configuration to twl-common
OMAP3: Move common twl configuration to twl-common
OMAP3: Move common regulator configuration to twl-common
Rajendra Nayak (6):
OMAP2+: PM: Initialise sleep_switch to a non-valid value
OMAP4: clock data: Add missing divider selection for auxclks
OMAP2+: PM: idle clkdms only if already in idle
OMAP2+: clockdomain: Add per clkdm lock to prevent concurrent state programming
OMAP2+: hwmod: Follow the recommended PRCM module enable sequence
OMAP3 PM: CPUFreq driver for OMAP3
Russell King (1):
OMAP2+: CPUfreq: update lpj with reference value to avoid progressive error.
Santosh Shilimkar (5):
OMAP4: clock data: Keep GPMC clocks always enabled and hardware managed
OMAP4: powerdomain data: Remove unsupported MPU powerdomain state
OMAP: cpufreq: Split OMAP1 and OMAP2PLUS CPUfreq drivers.
OMAP2PLUS: cpufreq: Add SMP support to cater OMAP4430
OMAP2+: CPUfreq: Remove superfluous check in target() for online CPU's.
Silesh C V (1):
OMAP: PM: CPUFREQ: Fix conditional compilation
Steve Sakoman (1):
mfd: twl-core: enable madc clock
Todd Poynor (2):
OMAP: VP: Explicitly mask VPVOLTAGE field
OMAP2+: cpufreq: Enable all CPUs in shared policy mask
Tomi Valkeinen (2):
OMAP4: hwmod data: Modify DSS opt clocks
OMAP4: hwmod data: Change DSS main_clk scheme
Tony Lindgren (10):
omap: Use separate init_irq functions to avoid cpu_is_omap tests early
omap: Set separate timer init functions to avoid cpu_is_omap tests
omap: Move dmtimer defines to dmtimer.h
omap: Make a subset of dmtimer functions into inline functions
omap2+: Use dmtimer macros for clockevent
omap2+: Remove gptimer_wakeup for now
omap2+: Reserve clocksource and timesource and initialize dmtimer later
omap2+: Use dmtimer macros for clocksource
omap2+: Remove omap2_gp_clockevent_set_gptimer
omap2+: Rename timer-gp.c into timer.c to combine timer init functions
Vaibhav Bedia (1):
OMAP: clockdomain: Remove redundant call to pwrdm_wait_transition()
To recreate it, download http://dominion.thruhere.net/koen/angstrom/beagleboard/3.0/patchset.tar.bz2 and run the patch script in a 3.0 git tree.
regards,
Koen
