Started some testing of the latest 3.14 build
(http://builds.beagleboard.org/builders/runtests/builds/27) today.
I found the 8-19 image from
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian seemed to require
me to copy a bbb-uEnv.txt file to uEnv.txt on the FAT partition to
make it boot from the microSD card. Seems to me that should be the
default.
Install with 'dpkg -i XXX.deb' and reboot was pretty easy.
Got an oops on mmcblk0 (microSD) (http://paste.debian.net/119196/):
[ 5479.495347] mmcqd/0: page allocation failure: order:1,
mode:0x204020 [ 5479.495395] CPU: 0 PID: 43 Comm: mmcqd/0 Not tainted
3.14.17-git302cf583bc3db28305d83071e50c957354e3111a #2 [ 5479.495458]
[<c0015cf0>] (unwind_backtrace) from [<c00128d0>]
(show_stack+0x10/0x14) [ 5479.495490] [<c00128d0>] (show_stack) from
[<c0762bb4>] (dump_stack+0x68/0x84) [ 5479.495526] [<c0762bb4>]
(dump_stack) from [<c00ea768>] (warn_alloc_failed+0xcc/0x10c) [
5479.495555] [<c00ea768>] (warn_alloc_failed) from [<c00ed7cc>]
(__alloc_pages_nodemask+0x7bc/0x960) [ 5479.495583] [<c00ed7cc>]
(__alloc_pages_nodemask) from [<c011f0fc>]
(cache_alloc_refill+0x358/0x58c) [ 5479.495605] [<c011f0fc>]
(cache_alloc_refill) from [<c011f5cc>] (__kmalloc+0x104/0x198) [
5479.495642] [<c011f5cc>] (__kmalloc) from [<c045ee14>]
(edma_prep_slave_sg+0x98/0x2d4) [ 5479.495674] [<c045ee14>]
(edma_prep_slave_sg) from [<c06099d8>]
(omap_hsmmc_request+0x3e4/0x4d8) [ 5479.495710] [<c06099d8>]
(omap_hsmmc_request) from [<c05f3b24>] (mmc_start_request+0x128/0x250)
[ 5479.495737] [<c05f3b24>] (mmc_start_request) from [<c05f4bc4>]
(mmc_start_req+0x170/0x32c) [ 5479.495774] [<c05f4bc4>]
(mmc_start_req) from [<c06021c8>] (mmc_blk_issue_rw_rq+0xc0/0xae8) [
5479.495800] [<c06021c8>] (mmc_blk_issue_rw_rq) from [<c0602e20>]
(mmc_blk_issue_rq+0x230/0x4d8) [ 5479.495825] [<c0602e20>]
(mmc_blk_issue_rq) from [<c06041e4>] (mmc_queue_thread+0x9c/0x13c) [
5479.495855] [<c06041e4>] (mmc_queue_thread) from [<c005fb20>]
(kthread+0xd0/0xf0) [ 5479.495880] [<c005fb20>] (kthread) from
[<c000eea8>] (ret_from_fork+0x14/0x2c)
Also, I have an Ethernet cable connected and that came up fine, but
the usb0 interface doesn't show up:
root@beaglebone:~# ifconfig
eth0 Link encap:Ethernet HWaddr 90:59:af:69:c0:42
inet addr:192.168.2.138 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::9259:afff:fe69:c042/64 Scope:Link
RX packets:513522 errors:0 dropped:0 overruns:0 frame:0
TX packets:109359 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:690469697 (658.4 MiB) TX bytes:15468479 (14.7 MiB)
Interrupt:56
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Hacking with cape-universal using dtb-builder right now. Another ugly
side-effect I'm seeing is that one of the pins seems to be driven,
despite me not setting it up as anything. I'm going to try to address
this in the dtb.
Beagleboard:BeagleBoneBlack Debian - eLinux.org seemed to require
default.
It became the default after 8-19..
Got an oops on mmcblk0 (microSD) (Debian paste error):
Weird, it comes up clean:
This is the "console" right? That doesn't do anything fancy, it just
boots with a very clean image. As that is what those users wanted..
Interrupt:56
this in the dtb.
default.
debian@beaglebone:~$ dmesg [ 0.000000] Booting Linux on physical CPU 0x0[ - Pastebin.com
No, I used the LXDE image.
default.
Interrupt:56
this in the dtb.
P9_42 is lighting up on microSD card activity at similar times to the USR1 LED.
I believe P9_42 is connected to balls C18 and B12 per the SRM and
schematic and that those refer to offsets 0x164 and 0x1a0
respectively.
/sys/kernel/debug/pinctrl/44e10800.pinmux/pinmux-pins:
pin 89 (44e10964.0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 104 (44e109a0.0): 48060000.mmc (GPIO UNCLAIMED) function
pinmux_mmc1_pins_sleep group pinmux_mmc1_pins_sleep
/sys/kernel/debug/pinctrl/44e10800.pinmux/pins:
pin 89 (44e10964.0) 00000027 pinctrl-single
pin 104 (44e109a0.0) 00000027 pinctrl-single
I don't know why it is allocated for the MMC and I don't see anywhere
it is physically connected, so I'm assuming this is somehow enabled in
this mmc function, but I don't know what the driver believes it to be.
The device tree assignment doesn't seem to indicate what pin is
considered to be what function: pinctrl-single,pins = <
0x0F0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x0F4 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x0F8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x0FC (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x100 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x104 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x1A0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x160 (PIN_INPUT_PULLDOWN | MUX_MODE7)
Also, can you explain how you envision different peripherals being
turned on with the current overlays? I still don't see how to use the
configurations you've set and
Beagleboard:Capes 3.8 to 3.14 - eLinux.org doesn't explain it
either.
