3.14 kernel with Android 4.4 fails with "untracked pid xxx exited"
Hi guys,
I’m trying to get the 3.14 kernel with Android 4.4 running.
I followed the instructions from http://android.serverbox.ch/?p=1278
The kernel boots. However, I get error messages regarding exiting an untracked PID:
[ 4.132841] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 4.141964] devtmpfs: mounted
[ 4.145627] Freeing unused kernel memory: 456K (c0a38000 - c0aaa000)
[ 5.880918] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 6.080660] init: cannot open ‘/initlogo.rle’
[ 6.110169] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[ 6.143925] EXT4-fs (mmcblk0p3): recovery complete
[ 6.152891] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
[ 6.165416] EXT4-fs (mmcblk0p4): Ignoring removed nomblk_io_submit option
[ 6.538227] EXT4-fs (mmcblk0p4): recovery complete
[ 6.546819] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
[ 8.041834] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 8.084971] init: cannot find ‘/system/bin/rild’, disabling ‘ril-daemon’
[ 8.098345] healthd: No charger supplies found
[ 8.103034] healthd: BatteryStatusPath not found
[ 8.123663] healthd: BatteryHealthPath not found
[ 8.129798] healthd: BatteryPresentPath not found
[ 8.137261] healthd: BatteryCapacityPath not found
[ 8.142789] healthd: BatteryVoltagePath not found
[ 8.148583] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
[ 8.158142] healthd: BatteryTemperaturePath not found
[ 8.169393] healthd: BatteryTechnologyPath not found
[ 8.176491] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
[ 8.187024] binder: 86:86 transaction failed 29189, size 0-0
[ 8.193674] init: powerctl: cannot expand ‘${sys.powerctl}’
[ 8.200360] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
[ 8.212474] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
[ 8.224145] init: property ‘sys.sysctl.tcp_def_init_rwnd’ doesn’t exist while expanding ‘${sys.sysctl.tcp_def_init_rwnd}’
[ 8.236207] init: cannot expand ‘${sys.sysctl.tcp_def_init_rwnd}’ while writing to ‘/proc/sys/net/ipv4/tcp_default_init_rwnd’
shell@armv7-a-neon:/ $ [ 9.365233] random: nonblocking pool is initialized
[ 9.483469] init: untracked pid 152 exited
[ 14.020018] init: untracked pid 178 exited
[ 18.571949] init: untracked pid 204 exited
[ 24.740388] init: untracked pid 384 exited
[ 24.747916] init: untracked pid 385 exited
[ 29.279267] init: untracked pid 409 exited
Does anyone know how debug this? What fails here?
It seems something from init does not work properly.
Thanks in advance
Robert
Have you gone past through this or still struggling ?
bumping this up, Having the same issue too.
