3D Accelerator
Hi
How do we know whether the 3D accelerator is working or not in a BBB?
For one.. You need to manually install it..
http://elinux.org/BeagleBoardDebian#SGX_BeagleBone.2FBeagleBone_Black
hi
If an input device is created then /dev/input/event* should exist
Compile evtest.c which attached
and use command evtest /dev/input/event* should give you some events when you turn up and down
evtest.c (14.8 KB)
