4D Systems 7" LCD working with Jessie?
I just tried booting a brand-new BBB with 4D Systems 7" cap touch LCD cape. I get this with the BBB-blank-debian-8.10-lxqt-4gb-armhf-2018-03-06-4gb.img image. The checksum and Etcher verification both passed.
U-Boot SPL 2016.01-00001-g4eb802e (Jan 13 2016 - 11:14:31)
Trying to boot from MMC
bad magic
U-Boot 2016.01-00001-g4eb802e (Jan 13 2016 - 11:14:31 -0600), Build: jenkins-github_Bootloader-Builder-313
       Watchdog enabled
I2C: ready
DRAM: 512 MiB
Reset Source: Global warm SW reset has occurred.
Using default environment
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
Scanning mmc 1:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
1684 bytes read in 14 ms (117.2 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.1.15-ti-rt-r43 ...
7800752 bytes read in 442 ms (16.8 MiB/s)
loading /boot/dtbs/4.1.15-ti-rt-r43/am335x-boneblack.dtb ...
60524 bytes read in 39 ms (1.5 MiB/s)
loading /boot/initrd.img-4.1.15-ti-rt-r43 ...
4096241 bytes read in 240 ms (16.3 MiB/s)
debug: [console=ttyO0,115200n8 root=UUID=e2d8ea76-265d-4adb-b4d1-2bb8b0cb39df ro rootfstype=ext4 rootwait coherent_pool=1M quiet cape_universal=enable] ...
debug: [bootz 0x82000000 0x88080000:3e80f1 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x7707b0 ]
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8fc17000, end 8ffff0f1 ... OK
   Loading Device Tree to 8fc05000, end 8fc16c6b ... OK
Starting kernel ...
[ 3.486570] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 3.790295] cpu cpu0: cpu0 clock notifier not ready, retry
[ 3.963342] bone_capemgr bone_capemgr: slot #1: No cape found
[ 4.023318] bone_capemgr bone_capemgr: slot #2: No cape found
[ 4.083322] bone_capemgr bone_capemgr: slot #3: No cape found
Loading, please wait...
fsck from util-linux 2.25.2
/init: 379: /init: touch: not found
Usage: mount [-r] [-w] [-o options] [-t type] [-f] [-i] [-n] device directory
Target filesystem doesn't have requested /sbin/init.
mount: No such file or directory
No init found. Try passing init= bootarg.
[ 5.103796] bone_capemgr bone_capemgr: loader: failed to load slot-0 BB-BONE-4D7C-01:00A1 (prio 0)
(initramfs) [ 5.753303] mmc0: card never left busy state
[ 5.757616] mmc0: error -110 whilst initialising SD card
bad magic
This is ^^ too old, you need to use the U-Boot overlay path for any LCD..
Hold the boot select button down, or force a u-boot upgrade via:
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
       Watchdog enabled
I2C: ready
DRAM: 512 MiB
cpsw, usb_ether
Scanning mmc 1:1...
Wait a minute:, that's not
Whatever you are actually running is really old.
It was really confusing. I put the Jessie lxqt flasher on the SD card, and that’s what I got (the BBB eMMC had something from 2016 on it).
I was able to get the latest-releases stretch from 2018-01-28 (?) to load just fine (never once tried the boot button).
