i got a “switching adapter” with 5.2 Volt, 1A Output. It says nothing about Watt so i am not sure about this.
Is this safe to use without damaging the Board? The plug fits in.
Picture and details: https://imgur.com/a/Slsrk
Nope, 5V is not 5.2V...
from the PMIC data sheet
Absolute Maximum Ratings
Supply voltage (with respect to PGND) AC -0.3 20
Recommended Operating Conditions
Supply voltage, AC 4.3 5.8 V
They call the power input AC but its really DC only
You can use that power supply. But the recommended power supply is a
good quality 5v 2 amp supply
Disclaimer. I do not recommend you use it but the PMIC data sheet says
its just fine.
Should also be aware that the given plug with that power supply could potentially be reversed polarity. In which case it’ll fry your beaglebone.
