6 Channel Audio and the Beagle Board
I wish to put together a hobbyist Set Top Box (STB) with the Beagle
Board. For this purpose, it would be nice to have the ability to
render 6 channel audio. What are the options for this with regard to
the beagle board? I can think of USB Audio as one. Any others?
Thanks.
The expansion connector has a I2S on it that could be used as what we call a McBSP, which could support multiple CODECS. You would need to pick the CODECS to use and create a board to support it…
Thanks Gerald. Now let me hurry to research that :slight_smile:
Read the System Reference Manual and the OMAP3 data manual.
Thanks. Just now downloading the data manual.
On a related question, how about getting audio output through a
normal, stereo A/V cable, as most televisions expect audio input from
such a connector?
Thanks.
There is a 3.5mm stereo jack on the board from the TWL4030. You should be able to get an adapter cable that converts it to a RCA style jack.
Gerald Coley wrote:
Thanks a lot guys.
Got my beagle board today too:)
