It seems to be really tiny & cheap.
2Ghz over-clock with a heat sink?
http://www.cnx-software.com/2012/11/30/69-odroid-u-89-odroid-u2-exynos-4412-development-boards/
The heat sink is Huge!
This toy is really appealing to play with but not for further development of any system. Same as with R-Pi. Samsung will make another CPU for smartphones in 6 months and this one will be obsolete
Im surprised with this
The heatsink also serves as an enclosure.
The CPU module of the ODROID-X which it's based on gets quite hot and powers down with large compiles such as building a kernel with "make -j 4". A 2" x 2" fan placed above it makes it run cool.
Still quite useful and a good price, think of a quad-core Pandaboard that runs at 1.6GHz.
Time taken to build Ubuntu linux-image and linux-header deb packages and uImage is impressive with no need to cross compile.
I use a 32GB full size Class 10 SD card - microSD cards in an adaptor do not work as the adaptor distorts the signals.
I have added a 60GB USB IDE HD and also nfs mounted a HD from my main x86_64 box with 512GB spare.
root@ODROID-X_G3VBV:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p3 30G 9.2G 19G 34% /
udev 483M 4.0K 483M 1% /dev
tmpfs 199M 2.7M 196M 2% /run
none 5.0M 0 5.0M 0% /run/lock
none 497M 18M 480M 4% /run/shm
cgroup 497M 0 497M 0% /sys/fs/cgroup
/dev/mmcblk0p2 52M 30M 22M 58% /media/boot
/dev/sda1 52G 5.8G 43G 12% /media/ffa77416-f4d4-423f-81d0-cebfbef538f5
slipstream:/home/lancelot/ftp 857G 293G 521G 36% /3
Regards
Sid.
