720MHz kernel complain
Hi!
I’m using OMAP3530 720MHz and the software from http://www.angstrom-distribution.org/demo/beagleboard/. It is not Beagle and there are no magic pins to detect BB revision. But the board has BB C3 based schematics, at least 99% from that.
In u-boot I setenv mpurate to 720 and during the kernel booting I see the following:
[ 117.316192] Power Management for TI OMAP3.
[ 117.321289] ------------[ cut here ]------------
[ 117.325958] WARNING: at arch/arm/mach-omap2/dpll.c:439 omap3_noncore_dpll_set_rate+0x228/0x26c()
[ 117.334808] Modules linked in:
[ 117.337921] [] (unwind_backtrace+0x0/0xdc) from [] (warn_slowpath_common+0x4c/0x80)
[ 117.347351] [] (warn_slowpath_common+0x4c/0x80) from [] (omap3_noncore_dpll_set_rate+0x228/0x26c)
[ 117.358032] [] (omap3_noncore_dpll_set_rate+0x228/0x26c) from [] (omap2_clk_set_rate+0x24/0x34)
[ 117.368530] [] (omap2_clk_set_rate+0x24/0x34) from [] (clk_set_rate+0x4c/0xbc)
[ 117.377563] [] (clk_set_rate+0x4c/0xbc) from [] (omap2_clk_set_freq+0x264/0x410)
[ 117.386749] [] (omap2_clk_set_freq+0x264/0x410) from [] (omap3_sr_init+0xe0/0x174)
[ 117.396118] [] (omap3_sr_init+0xe0/0x174) from [] (do_one_initcall+0x5c/0x1bc)
[ 117.405120] [] (do_one_initcall+0x5c/0x1bc) from [] (kernel_init+0xa4/0x128)
[ 117.413970] [] (kernel_init+0xa4/0x128) from [] (kernel_thread_exit+0x0/0x8)
[ 117.422821] —[ end trace e21b05380063814d ]—
[ 117.427856] Switched to new clocking rate (Crystal/Core/MPU): 26.0/166/720 MHz
Angstrom further works, but I don’t consider this as a good behavior. Any suggestions?
regards,
Max
That error is expected and reportedly harmless.
regards,
Koen
