Hello
What is the part number of the NEC displays that you have? Also,
forgive my ignorant questions but I'm very new to this board and LCD
screens in general.
So I'd kindly suggest you do not try to hack them at the moment. As
you said, if you hook up the LCDs to the board they will not work
immediately. Some hardware is needed, mostly for voltage conversion,
and certainly some software adaptation will be needed too.
I'll be happy to send you a LCD panel as soon as they are working
reliably. At the moment, we're just experimenting.
The other day I was ready to blow a couple of screens with my poor
hardware skills just to try to see if I could get something -
anything.
Then I though it'd be better to offer the straw screens to people who
can get a result without taking as much risks of killing them in the
process
Why would you need a switch to toggle between DVI and LCD?
Because IIRC the same lines were used for DVI and LCD. I don't know if
they bear the same signals- but even them, since both screens are
likely to have different resolutions, I don't think it wouldn't be a
good idea to try to hook them up at the same time and see what
happens. Yet I'm no hardware guy - can't say for sure.
I may be interested, and I have everything needed to drive one.
Then it's yours.
I have a whole collection of NL 6448AC33-xx nec screens for testing in
medial devices, with xx={29, 24, 18, 10} for different color depths,
If you need a light one, I can send you a Optrex DMF-50260NFU-FW-23
along with its FPC cable. It's much much lighter. But unlike the nec
I don't have any others. You'll be on your own.
What is the weight of one of the lcd panels?
Hard to say. The lightest one weights less than my thinkoutside mini
mouse - I'd guesstimate that to 200g. Honnestly with some good padding
I think it'll perfectly fit in an enveloppe.
PS: if you succeed, could I ask you a RevC LCD breakerboard to access
the LCD signals on big molex connectors
I'd like to play too !
Guylhem
