8192.ko Module Format Error on Debian
I am using the debian wheezy image form here with Robert Nelson’s kernel
http://www.armhf.com/index.php/boards/beaglebone-black/#wheezy
I am trying to get my little edimax usb wifi to work. So far i have determined that the modules that come with debian right now do not work with my dongle. So I built my own from source using the following process on the beaglebone black itself.
Get headers from the kernel dev’s site. These match the kernel at the current time
wget http://rcn-ee.net/deb/wheezy-armhf/v3.8.13-bone20/linux-headers-3.8.13-bone20_1.0wheezy_armhf.deb
dpkg -i linux-headers-3.8.13-bone20_1.0wheezy_armhf.deb
Still need more source. Need to get mainline source and then patch it
wget https://www.kernel.org/pub/linux/kernel/v3.0/linux-3.8.13.tar.bz2
wget http://rcn-ee.net/deb/wheezy-armhf/v3.8.13-bone20/patch-3.8.13-bone20.diff.gz
wget http://rcn-ee.net/deb/wheezy-armhf/v3.8.13-bone20/defconfig
Uncompress source & wait
tar xvjf linux-3.8.13.tar.bz2
Cd /linux-3.8.13
Apply Patch. If patch doesn’t exist then apt-get install patch
zcat …/patch-3.8.13-bone20.diff.gz | patch -p1
copy defconfig:
cp …/defconfig .config
Put it in the correct directory
sudo mv linux-3.8.13 /usr/src/
cd /usr/src/linux-3.8.13
sudo make oldconfig
sudo make prepare
sudo make modules_prepare
Go back to driver source folder
Cd ~/wifi/rtl8188C_8192C_usb_linux_v3.4.4_4749.20121105
follow instructions on http://bonenotes.tumblr.com/ to patch source
wget [https://raw.github.com/cmicali/rtl8192cu_beaglebone/master/util/rtl-8192-beaglebone-linux-3.8.patch](https://raw.github.com/cmicali/rtl8192cu_beaglebone/master/util/rtl-8192-beaglebone-linux-3.8.patch)
patch -p1 < rtl-8192-beaglebone-linux-3.8.patch
make KSRC=/usr/src/linux-3.8.13/ CROSS_COMPILE= ARCH=arm
sudo insmod 8192cu.ko
Error: could not insert module 8192cu.ko: Invalid module format
some other info
$ lsmod
Module Size Used by
c_can_platform 4645 0
c_can 9223 1 c_can_platform
can_dev 8944 1 c_can
dmesg
[ 1749.507523] 8192cu: no symbol version for module_layout
$ uname -r
3.8.13-bone20
ls -l /lib/firmware/rtlwifi/rtl8712u.bin
-rw-r–r-- 1 root root 122328 Jan 6 2013 /lib/firmware/rtlwifi/rtl8712u.bin
$ lsusb
Bus 001 Device 002: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Only error i saw during the process
make ARCH=arm CROSS_COMPILE= -C /usr/src/linux-3.8.13/ M=/home/debian/wifi/rtl8188C_8192C_usb_linux_v3.4.4_4749.20121105 modules
make[1]: Entering directory `/usr/src/linux-3.8.13’
WARNING: Symbol version dump /usr/src/linux-3.8.13/Module.symvers
is missing; modules will have no dependencies and modversions.
some searching on the internet indicates that this is the result of the incorrect source version for the kernel that is being run. I’m a little lost on how that would happen.
Just use gkanidl's script to setup the correct source tree:
wget https://raw.github.com/gkaindl/beaglebone-ubuntu-scripts/master/bb-get-rcn-kernel-source.sh
chmod +x bb-get-rcn-kernel-source.sh
./bb-get-rcn-kernel-source.sh
then patch the src, build, etc..
that solved the issue i was having. Thank you and gkanidl for the great script and kernel.
for those who are attempting to do the same thing. here are what the complete instructions should be. It is worth noting that this module works with the version of hostapd that is included in the zip from realtek. I’ll post some instructions later.
To get the Edimax EW-7811Un usb wifi adapter to work on debian with Robert Nelson’s kernel
Get kernel source, headers and patch using script
Get wifi driver source and compile
Following steps from http://bonenotes.tumblr.com/
Download the Unix/Linux driver from the Realtek web site - It will be called something like RTL8192xC_USB_linux_v3.4.4_4749.20121105.zip
Unzip the file and then unpack the driver source which is driver/tl8188C_8192C_usb_linux_v3.4.4_4749.20121105.tar.gz in the zip file
cp rtl8188C_8192C_usb_linux_v3.4.4_4749.20121105.tar.gz ~/
tar xvfz rtl8188C_8192C_usb_linux_v3.4.4_4749.20121105.tar.gz
cd rtl8188C_8192C_usb_linux_v3.4.4_4749.20121105
Download this patch to add BB config and to fix building on linux 3.8 into the driver directory and apply it
wget https://raw.github.com/cmicali/rtl8192cu_beaglebone/master/util/rtl-8192-beaglebone-linux-3.8.patch
Build the driver
make CROSS_COMPILE=
Install the driver, as root
make install
edit the file “/etc/modprobe.d/blacklist.conf” and add the line so that the old module is not used.
blacklist rtl8192cu
Load module, as root
modprobe 8192cu
The module should load itself at reboot
It’s awesome that you got it to work .I tried to do the same to rtl8192eu and sadly the patch by cmicali does not work. Is there any chance to get it to work.Or should I ask cmicali for instructions on patching.Thank you.
