9.4 debian wifi connmanctl error wlan0
I have been able to connect wlan0 using debian 8.4 using connmanctl as others have suggested but cannot with the latest 9.4 debian release. I get an abort from connmanctl. See below. Does anyone have a suggestion?
debian@192.168.7.2:~$ sudo connmanctl
[sudo] password for debian:
Error getting VPN connections: The name net.connman.vpn was not provided by any .service filesconnmancconnmanctl> tether wifi disable
Error disabling wifi tethering: Already disabled
enable wifi
Error wifi: Already enabled
scan wifi
Scan completed for wifi
services
c4control wifi_a4d5786d4f01_6334636f6e74726f6c_managed_wep
MMA-2.4 wifi_a4d5786d4f01_4d4d412d322e34_managed_psk
agent on
Agent registered
connect wifi_a4d5786d4f01_4d4d412d322e34_managed_psk
Agent RequestInput wifi_a4d5786d4f01_4d4d412d322e34_managed_psk
Passphrase = [ Type=psk, Requirement=mandatory, Alternates=[ WPS ] ]
WPS = [ Type=wpspin, Requirement=alternate ]
Passphrase? xxxxxx
Agent ReportError wifi_a4d5786d4f01_4d4d412d322e34_managed_psk
connect-failed
Agent request cancelled by ConnMan
Error /net/connman/service/wifi_a4d5786d4f01_4d4d412d322e34_managed_psk: Operation aborted
Can you share a link to which Debian image you’re using?
This is on which model beaglebone?
As for suggestions... run apt-get update and upgrade.
Try an open WiFi network to see if it has something to do with the encryption.
