A DVI-D to TTL LCD converter
Hi guys,
  I tried searching for DVI-D to TTL LCD converter and found this
small one:
http://www.aaeon.com/PD_Products_Detail_AEEE87FC762C45F1AC_F67467B5A6BD44F0B9_30D6012CD30E4BAAAC_US_utf-8.html
  I found out from the company that it comes in three versions for
different resolutions:
    * TF-PER-V01B-A10
      Mini PCI DVI to TTL LCD Signal Conversion Module for 640x480
Panel Rev. A1.0
    * TF-PER-V01B-A10-01
      Mini PCI DVI to TTL LCD Signal Conversion Module for 800x600
Panel Rev. A1.0
    * TF-PER-V01B-A10-02
      Mini PCI DVI to TTL LCD Signal Conversion Module for 1024x768
Panel Rev. A1.0
  Unfortunately (for me) they said they don't have any for 320x240 or
480x272 type screens.
   Bert
Hi Bert,
It appears the Silicon Image DVI deframer/deserialiser/receiver that
they use on those boards only likes working at pixel frequencies
between 25MHz and 165MHz, which limits you to a range of (fairly high)
resolutions.
It also seems that the TFP410 DVI transmitter on the beagleboard has a
similar limitation in that it wants to work at a minimum of 25MHz
pixel clock too, so even if you find a receiver that's able to lock at
very low frequencies you might not get sense out of the beagleboard at
those rates.
(For reference, I'm working from 480x272x50Hz having a pixel clock of
about 6.5MHz and 320x240x50Hz about 3.8MHz.)
I wouldn't feel confident about being able to drive such a small
display from the beagleboard using parallel->DVI->DVI->parallel,
perhaps Gerald/the paid BB hardware guys could advise about the
transmitter.
If you are very good at soldering and willing to take the risk of
ruining your BB it is technically possible to find the LCD data on the
board itself (it is fed from the OMAP3 to the TFP410) and bringing it
out to, say, a TFT panel from a Sony PSP (480x272 :wink: ) "should work",
the speeds aren't superhigh at those resolutions. Note you'd have to
buffer the (IIRC 1.8V) outputs up to the (probably) 3.3V input the
display would be expecting. But don't take my advice. =)
Cheers,
Matt
Thanks for the info Matt. I might attempt that bit of soldering. If I can’t, I’ll just use the beagle board as a temporary development platform using a DVI monitor for developing my app until Gumstix comes out with their OMAP board with those signals brought out to connectors for an easier small LCD interface.
Bert
> Hi guys,
> small one:
> [snip]
Hi Bert,
resolutions.
those rates.
transmitter.
Based on these restrictions, it may still be possible to drive the lower
resolution LCDs. I think there is hardware support in the lcd controller
for pixel doubling. With this, it may be possible to setup a CPLD (small
device like the a 22V10 or smaller) to divide the clocks seen by the LCD
by 2 in X and 2 in Y. Using those figures above, a panel wanting around
6MHz can probally be driven by a 24MHz clock through the DVI processes.
The chain would be something like
OMAP parallel -> DVI -> DVI -> Parallel -> CPLD -> Panel
-- Hunyue
I've found a 3.5" 640x480 screen, the AND-TFT-35VX from here (http://
www.purdyelectronics.com/products/displays/tftmonit.cfm) The
datasheet says it takes 25MHz clock, so it could work with the DVI
receiver chip (SiI1161CTU) on the PER-V01B DVI converter.
Bert
