A working xorg.conf anyone?
Angstrom distro - I get a blank screen when X starts or using xdm from
another box.
Trying xorgconfig I still got "no screens found" - changed "vga" to
"omapfb". I have a 19" LCD screen using the DVI input.
Regards
Sid.
This is as far as it gets with the distro's xorg.conf
Xorg.0.log_beagle (8.69 KB)
   Sorry, I can't interpret the log. However, I add below, the
xorg.conf that is currently used in my BB with Angstrom. Maybe, this
helps. The screen is 19" LCD dvi input, same as yours. I got no
problem in display.
   BTW, I'm trying to establish a remote connection to BB. I failed
yet. You mentioned about xdm from a remote box. How could you setup
the xdm server open for remote access?
Caner
xorg.conf:
Section "Module"
        Load "extmod"
        Load "dbe"
        Load "glx"
        Load "freetype"
        Load "type1"
        Load "record"
        Load "dri"
EndSection
Section
"Monitor"
        Identifier "Builtin Default Monitor"
EndSection
Section "Device"
        Identifier "Builtin Default fbdev Device 0"
        Driver "omapfb"
EndSection
Section "Screen"
        Identifier "Builtin Default fbdev Screen 0"
        Device "Builtin Default fbdev Device 0"
        Monitor "Builtin Default Monitor"
EndSection
Section "ServerLayout"
Layout"
        Screen "Builtin Default fbdev Screen 0"
EndSection
problem in display.
Your xorg.conf is exactly the same.
"X -query <IP_address_of_beagleboard> :1" should give a login screen for
the beagleboard on VT8, assuming VT7 is used for display :0.
In /etc/X11/Xaccess uncomment the lines
* CHOOSER BROADCAST #any indirect host can get a chooser
* #any host can get a login window
What I am seeing in Xorg.0.log is
        ABI class: X.Org Server Extension, version 2.0
That log shows X is working fine, I suspect you failed to see if the DVI port works at all in your current video setting.
OK, I shall check the specs for the monitor to see if it supports 6.
I am using the default xorg.conf and it doesn't report that it is unable
to use that resolution..
(--) omapfb(0): Virtual size is 640x480 (pitch 640)
The keyboard also defaults to "US" and I'd like to change it to "gb".
Regards
Sid.
The LCD is set for 640x480 @ 59Hz
Specs
   Maybe I should have carried this topic to a new thread.
   Sid, thanks for the solution. But I failed. Well, I tried "X -
query <IP_address_of_beagleboard> :1" at client side which is Ubuntu
9.04, it destroyed the current X session, and tried to start some kind
of new session, I couldn't figure it out since nothing but a black
screen appeared. I also checked /etc/X11/Xaccess file, couldn't find
it. In addition, I searched Xaccess in whole disk, still no result.
Angstrom is running on Beagleboard. Did you setup some additional
packages at serverside? And, I really got confused about X command.
Regards
Caner
Regards
Caner
With X on Linux, you have access to virtual screens (:0 :1 :2, etc.) on
which you can manage many machines, switching between them with
CTRL-ALT-Fkeys
It works like this ... you have your first session (Ubuntu) running on
VT7 (:0), it switched to VT8 (:1) to open a login screen from the
beagleboard which it obviously didn't get - hence the black screen on :1.
CTRL-ALT-F7 takes you back to your main Ubuntu session on :0 which is
still alive and well. CTRL-ALT-F8 would take you back to the failed
beagleboard login attempt.
As an example as to how I managed multiple Solaris partitions from a
Linux laptop, something that couldn't be done from Solaris or Windows, I
opened one session on :1, one on :2, one on :3 and one on :4,
CTRL-ALT-F7 from any session would take me to :0 (my main Linux
session), CTRL-ALT-F8 switches to :1, CTRL-ALT-F9 to :2, etc. to go to
any session I have running.
I am still having problems with X on the beagleboard and the result of
"X -query 192.168.10.176 :1" takes me to VT8 and the black screen which
eventually dies, but immediately CTRL-ALT-F7 takes me back to my main
session.
When it works, it gives you a beagleboard X session.
Regards
Sid.
Tried a new MMC card with
Angstrom-Beagleboard-demo-image-glibc-ipk-2009.X-stable-20090612--beagleboard.rootfs.tar.bz2
and modules-2.6.29-r37-beagleboard.tgz, an X login is OK, but not the
USB network dongle, so no network.
On the original card using unstable, I have to start X manually but the
screen comes up blank.
"Xorg -br -nolisten tcp :0 vt6&" or just "Xorg &"
The unstable branch was generated using the tool.
My_Beagle-66007649-image-beagleboard.tar.bz2
On other thing, the USB appears to go to sleep (hub lights go out) and
can only be awaken by a reboot.
Regards
Sid.
