[Reposted to add better categories. Will delete original.]
I’m trying to write a kernel driver that accesses an existing spi device – in particular, I already have /dev/spidev1.0 active and working, and I’d like to be able to use kernel spi_write(), etc, calls on that device. I’m using linux 3.8.13-bone70.
I can get at the spi master with spi_busnum_to_master(), but it seems to me that I should be able to get the existing spi_device from some api interaction with the master, but I don’t see any such thing. I also can’t use spi_new_device() to create a “new” device (if that is the correct way to do it) because there’s a chipselect conflict – this seems to be almost an FAQ for spi users, and I’ve looked a that some and would rather not try to go that that path – at a minimum it would require rewiring our custom cape.
I imagine I could do most of what I want simply in user code, with /dev/spidev1.0, but I expect a latency issue and I’d rather try to do it the best way, from that point of view, which is to be in a kernel driver.
Thanks for any advice.
