Add a sensitive motion detector, and also to send a picture
Hi All,
I would like to develop a system that detracts a motion ,Photo it and transmit it .
Did someone done it before or give me any advice if one of the Beagle can support it easily.
Thank you
On Sun, 26 Mar 2017 00:17:33 -0700 (PDT), ram30
<markeli2234@gmail.com> declaimed the
following:
Hi All,
transmit it .
  First question: what type of motion sensor are you planning to use...
After all, the required sensor code will be much different for a PIR vs a
vibration sensor vs a MEMS accelerometer.
  What type of camera?
  "transmit it" HOW? Wired ethernet to an email server, WiFi to a NAS
drive in some closet?
support it easily.
  Presuming a PIR sensor, I'd suggest looking at
(it shouldn't be too difficult to translate RPI I/O access to BBB I/O)
(again, you'd have to map the I/O functions to the BBB equivalent)
Yes, this can be done. In fact I’m working on a system right now that does something similar to this. I can not get into much detail of this project, as there is an NDA involved.
What I could say however, is that you may want to look into using a PIR sensor, which can be had fairly inexpensively to toggle a GPIO, with a “file watcher” script, or executable that will call another script or executable( could be an all in one executable ) that may trigger an event. Which could be used to take a picture of whatever is in front of the camera.
