Adding PRU eCAP to beaglebone-universal-io
Doing event capture with the PRU’s eCAP peripheral is absolutely perfect for my application. And TI’s newer “pru_ecap.h” header and their (very thorough) Technical Reference Manual make it look pretty easy. I only wish I could get that far!
It looks like the “pr1_ecap0_ecap_capin_apwm_o” signal (which sounds like what I need) is exposed on P9_42 in mode 3 (and maybe P8_15 in mode 5 too?), but beaglebone-universal-io doesn’t expose that pinmux on either pin.
Adding it myself looked pretty straightforward, though I’m still very new to device tree overlays. This is what I’ve come up with so far: http://pastebin.com/TAH2GHFT
That compiles but then config-pin errors out with something like “/bin/bash error on line 0” (not exact; I’m away from that machine). I’m hoping that I’m just missing something obvious and that someone with more device tree experience will spot it right away.
If anyone has any advice, I would be grateful! Hopefully once this is working, it can get rolled back into beaglebone-universal-io so everyone has easier access to this powerful peripheral.
Thanks!
Nicholas
The changes to both the device-tree and config-pin scripts look OK.
Given the error, I'm wondering if you maybe edited the config-pin
script on a Windows machine and got line-endings messed up? That will
confuse bash to no end. :slight_smile:
Otherwise, you can verify the device-tree changes work by poking
around manually in sysfs, and use standard script debugging to figure
out what's wrong with config-pin (try "set -xv" to start).
Thanks for the super fast reply, Charles! (And thanks for beaglebone-universal-io. It makes development on the BBB actually-approachable!)
I have access to the device now, so here is the real error message:
(This is after a reboot, make, make install, and echoing the universal cape to the cape manager)
./config-pin -a P9_42 ecapin
bash: line 0: echo: write error: No such device
Tracking it down a bit, I can produce the same message by doing what config-pin is trying to do:
/sys/devices/ocp.3/P9_42_pinmux.47# echo ecapin > state
bash: echo: write error: No such device
So now my question is which magic word does “state” want to see? (Things like “gpio” and “pwm” work just fine there.) I had picked “ecapin” to try and match the style of the other names. Is there a premade identifier someplace that has to be used instead or is that free-form text that just has to match the line in dts?
Is this something that needs to be added to the kernel before it will work? (I’m using 3.8.13-bone73.)
Thanks again,
Nicholas
# ./config-pin -a P9_42 ecapin
So now my question is which magic word does "state" want to see? (Things
like "gpio" and "pwm" work just fine there.) I had picked "ecapin" to try
It just has to match what you put in DTS.
(I'm using 3.8.13-bone73.)
My guess is you're actually using the unmodified overlay and not your
tweaked version. If so, you're tripping over the pre-compiled DT
overlays included in the kernel.
The workaround is to rename your modified *.dtbo overlay file to
something new so it won't be found in the compiled-in list and the
kernel will look for the file in /dev/firmware.
...or update the kernel source and build a new kernel. :wink:
You are my hero! Renaming the dtbo was all it took and my PRU eCAP test worked on the first try.
Now that I know it works, this feels like the kind of thing I should submit as a pull request. Assuming that’s alright with you, I’m guessing my next steps are to clean this up a bit, drop my custom-named version, also add and test the same mapping on P8_15, then duplicate all of that in the universaln and universala versions, too. Is there anything else I’m missing?
Thanks so much! Cheers,
Nicholas
I'm glad it's working! The compiled-in overlay files has bitten me
more than once as well. :slight_smile:
The changes you list sound good, I look forward to the PR. Holler if
you get stuck or have any questions.
