While I’d usually use MMC1 as brought out to the expansion connector of the beagle bone for an additional mmc card I just ordered a 1.8 inch color display from adafruit that has SPI display and sd card holder on board, both connected to the SPI bus. http://www.adafruit.com/products/358 . Is there a fairly easy way to have the SD card on this board recognised and used by the kernel as simply another block device containing one or more filesystem partitions such that I could simply mount and use normally a SD card inserted there (even if a bit slower due to access via SPI)?
Eric
