Running into an issue where we were able to see console output on the serial console when no JTAG or CCS was connected. After connecting CCS to JTAG and updating the DDR3 gel file we were able to see the output over the CCS serial console. After disconnecting the JTAG and CCS and doing a board reset, we can no longer see anything over the original serial console. Disconnected the serial console, did hardware reset, unplugged the BBB from the power supply and still the BBB simply appears hung or redirecting output or simply not responding CPU hung after power is applied.
What is causing this condition. It is fine when JTAG is connected and using CCS. But board appears hung with no CCCs or otherwise on reboot when JTAG and CCS is not connected. What is taking place?
