After /opt/scripts update usb network is not working
BBBlack, image: debian-7.11-lxde
how:cd /opt/scripts
git pull
After reboot there are two usb network interfaces (new is usb1). Both ip addresses are not reachable from windows (no route entry in route print), usb mass storage is still working.
Some logs:
[ 11.737870] usb0: HOST MAC 04:a3:16:af:a1:6d
[ 11.737981] usb0: MAC 04:a3:16:af:a1:6e
[ 11.738706] usb1: HOST MAC 1c:ba:8c:a2:ed:72
[ 11.738750] usb1: MAC 1c:ba:8c:a2:ed:73
[ 11.775559] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 11.775631] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.038548] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 12.117325] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 12.117431] configfs-gadget gadget: high-speed config #1: c
[ 12.117881] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
When I revert scripts to old version:
root@beaglebone:/opt/scripts# git reflog
a5d5f43 HEAD@{0}: pull: Fast-forward
ce39028 HEAD@{1}: pull: Fast-forward
b71b6d7 HEAD@{2}: clone: from https://github.com/RobertCNelson/boot-scripts
root@beaglebone:/opt/scripts# git reset --hard ce39028
then reboot abd usb0 192.168.7.2 is working again.
Best regards
Grzegorz
What kernel version? (uname -r) The dual usb's should only occur
after 4.4.x, since that's when we patched the rndis driver to support
Microsoft's built-in rndis driver (without a signed driver
installer)... The 2nd interface (usb-cdc) is for mac users..
https://github.com/RobertCNelson/boot-scripts/blob/master/boot/am335x_evm.sh#L652-L668
Linux beaglebone 4.4.39-bone15 #1 Sat Dec 17 16:14:57 UTC 2016 armv7l GNU/Linux
Driver on Windows:
Linux Developer Community
2012-04-27
6.0.6000.16384
signed by BeagleBoard.org Foundation
should I install other BONE_D64.exe file?
W dniu poniedziałek, 6 listopada 2017 17:12:49 UTC+1 użytkownik RobertCNelson napisał:
GNU/Linux
Crap, looks like i completely forgot to back port this patch from our
v4.4.x-ti tree to v4.4.x-bone
https://github.com/RobertCNelson/ti-linux-kernel-dev/blob/ti-linux-4.4.y/patches/drivers/gadget/0001-Change-USB-class-for-RNDIS.patch
(starting re-build now)
Driver on Windows:
2012-04-27
6.0.6000.16384
You can try, but it's probably expired, Micro$oft loves milking money
from developers..
and pushed as: "4.4.96-bone20"
Thank you very much :slight_smile:
Now latest is 4.4.71-bone17 (via ./update_kernel.sh --bone-kernel --lts-4_4)
Will 4.4.96-bone20 be available tomorrow or I need to change update parameters?
Ouch, yeah i stopped doing wheezy (7.x) builds when stretch (9.x) hit stable..
parameters?
voodoo@hades:~$ git clone -b am33x-v4.4
https://github.com/RobertCNelson/bb-kernel/ --depth=1
voodoo@hades:~$ cd bb-kernel/
voodoo@hades:~/bb-kernel$ ./build_deb.sh
Then copy the ./deploy/linux-image*.deb to your beagle and run:
sudo dpkg -i linux-image*.deb
sudo reboot
I did it. It took 1.5h on my debian virtual machine.
Results:
  • usb network i not available (still no route in route print),
  • serial over usb is working (it was not available before),
  • in device management there is working com port “USB serial device COM8” (mentioned above) and there is visible “Gadget serial COM7” defined not exsisted device,
  • big problems with RTC over I2C - almost not readable (before kernel upgrade, there was not as many problems with RTC over i2c),
  • old problem with ethernet is back
[ 158.682964] rtc-ds1307 1-0068: read error -121
[ 160.284608] rtc-ds1307 1-0068: read error -121
[ 201.901327] cpsw 4a100000.ethernet eth0: Link is Down
[ 402.656641] rtc-ds1307 1-0068: read error -110
[ 404.291265] rtc-ds1307 1-0068: read error -121
[ 407.762364] rtc-ds1307 1-0068: read error -121
[ 408.601046] rtc-ds1307 1-0068: read error -121
[ 411.371277] omap_i2c 4802a000.i2c: controller timed out
[ 411.376635] rtc-ds1307 1-0068: read error -110
[ 413.062533] rtc-ds1307 1-0068: read error -121
[ 413.983043] rtc-ds1307 1-0068: read error -121
I didn’t make any changes to kernel configuration (I did save, then exit).
PS. My OS is Windows 10 Fall Creators Update.
Did I miss something while compiling kernel?
W dniu poniedziałek, 6 listopada 2017 19:07:13 UTC+1 użytkownik RobertCNelson napisał:
Ethernet is working now… I don’t know why before link goes down. I can’t repeat this behaviour.
I have udev rule:
SUBSYSTEM==“rtc”, KERNEL==“rtc1”, SYMLINK+=“rtc”, OPTIONS+=“link_priority=10”, TAG+=“systemd”
when it is commented rtc problem remain.
W dniu środa, 8 listopada 2017 17:24:52 UTC+1 użytkownik Grzegorz G napisał:
this udev rule in un-reiable.. i fixed this in v4.4.x via, u-boot
overlays and a rtc cape overlay with the "alisas":
https://github.com/beagleboard/bb.org-overlays/blob/master/src/arm/BB-RTC-01-00A0.dts#L32-L40
Ok, I’ve updated and installed overlays again. No more errors in dmesg while read/write to RTC1, only init messages:
[ 4.293079] rtc-ds1307 1-0068: SET TIME!
[ 4.295910] rtc-ds1307 1-0068: rtc core: registered mcp7940x as rtc1
[ 4.295938] rtc-ds1307 1-0068: 64 bytes nvram
but RTC1 is not accessible:
root@beaglebone:/lib/firmware# date
Thu Nov 9 10:34:42 CET 2017
root@beaglebone:/lib/firmware# hwclock --rtc=/dev/rtc1
hwclock: Timed out waiting for time change.
hwclock: The Hardware Clock registers contain values that are either invalid (e.g. 50th day of month) or beyond the range we can handle (e.g. Year 2095).
root@beaglebone:/lib/firmware# hwclock --rtc=/dev/rtc1 --systohc
Can’t read or set valid time.
my boot/uEnv.txt file contains:
uname_r=4.4.96-bone20
cmdline=coherent_pool=1M quiet init=/lib/systemd/systemd
dtb=am335x-boneblack-emmc-overlay.dtb
cape_enable=bone_capemgr.enable_partno=BB-RTC-01,BB-UART1,BB-UART2,BB-UART4,BB-UART5
When old kernel 4.4.39-bone15 is used rtc is registered as below and is working fine:
[ 1.186751] rtc-ds1307 1-0068: SET TIME!
[ 1.189263] rtc-ds1307 1-0068: rtc core: registered ds1338 as rtc1
[ 1.189293] rtc-ds1307 1-0068: 56 bytes nvram
but after update and install overlays I got same error:
So, I’ve change file src/arm/BB-RTC-01-00A0.dts section:
mcp7940x@68 {
compatible = “microchip,mcp7940x”;
reg = <0x68>;
to compatible value from old version:
compatible = “maxim,ds1338”;
After this and update/install/reboot, rtc1 is working again! :slight_smile:
Next step is to check if it will be working with newest kernel aswell. It works!
The question is, why compatible “maxim,ds1338” was changed to “microchip,mcp7940x”?
Why aliases (rtc1 = “/ocp/rtc@44e3e000”) are not equal to kernel values: omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0? But this maybe doesn’t matter.
