After program on QT Creator, what should I do next?
I have a GUI program built on QT. I would like to know what should I do next to make it run on BeagleBoard? I guess I need to compile it by the ARM compiler and copy the binary to the SD card and make it run like other code? Do I need anything else?
Is there any difference if I want to make it run on DVI-LCD, S2-TV or LCD?
Best regards,
Thang NGuyen
Best regards,
Thang NGuyen
If you use OpenEmbedded, then you can use its Qt/Embedded toolchain:
http://docs.openembedded.org/usermanual/usermanual.html#id388002
Thank you so much.
This article may help:
http://bec-systems.com/site/501/best-practices-for-building-qt-applications-with-openembedded
Cliff
