I have generated a boot image for Beaglebone AI-64 using omap-image-builder.
Following commands are executed for generating the boot image (SD-Card Image):
./RootStock-NG.sh -c bb.org-debian-bullseye-xfce-edgeai-v5.10-ti-arm64.conf
cd deploy/debian-11.4-xfce-edgeai-arm64-2022-07-29/
sudo ./setup_sdcard.sh --img-10gb bbai64-debian-11.4-yantrr-2022-07-29 --dtb hwpack/j721e-evm.conf --distro-bootloader --hostname yantrr
On booting with above SD-card boot image, I tried to flash it on eMMC using command beagle-flasher
but getting following output with error and eMMC flashing is failed.
Version: [1.20220112.0: add cleanup grow_partition.service and beagle-flasher-init-shutdown.service...]
cat /etc/default/beagle-flasher:
source=/dev/mmcblk1
destination=/dev/mmcblk0
rfs_partition=dual
rfs_boot_startmb=1
rfs_boot_size_mb=128
bootloader=/opt/u-boot/bb-u-boot-beagleboneai64/install-emmc.sh
flash_back=bbai64-emmc-to-microsd
extlinux=/opt/u-boot/bb-u-boot-beagleboneai64/emmc-extlinux.conf
INFO: [lsblk -i]
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0 179:0 0 14.6G 0 disk
|-mmcblk0p1 179:1 0 128M 0 part
`-mmcblk0p2 179:2 0 14.5G 0 part
mmcblk0boot0 179:256 0 4M 1 disk
mmcblk0boot1 179:512 0 4M 1 disk
mmcblk1 179:768 0 29.7G 0 disk
|-mmcblk1p1 179:769 0 128M 0 part /boot/firmware
`-mmcblk1p2 179:770 0 29.6G 0 part /
INFO: copying [/dev/mmcblk1] -> [/dev/mmcblk0]
INFO: [source=/dev/mmcblk1] is a valid block device
INFO: [destination=/dev/mmcblk0] is a valid block device
INFO: [/boot/config-5.10.120-ti-arm64-r55]
INFO: Generating: [/boot/initrd.img-5.10.120-ti-arm64-r55]
update-initramfs: Generating /boot/initrd.img-5.10.120-ti-arm64-r55
W: Possible missing firmware /lib/firmware/xc3028L-v36.fw for built-in driver tuner_xc2028
W: Possible missing firmware /lib/firmware/xc3028-v27.fw for built-in driver tuner_xc2028
W: Possible missing firmware /lib/firmware/dvb-fe-xc4000-1.4.fw for built-in driver xc4000
INFO: flush_cache: [blockdev --flushbufs /dev/mmcblk0]
INFO: Erasing: [/dev/mmcblk0]
INFO: [dd if=/dev/zero of=/dev/mmcblk0 bs=1M count=148 status=progress]
148+0 records in
148+0 records out
155189248 bytes (155 MB, 148 MiB) copied, 7.21949 s, 21.5 MB/s
INFO: [dd if=/dev/mmcblk0 of=/dev/null bs=1M count=148 status=progress]
148+0 records in
148+0 records out
155189248 bytes (155 MB, 148 MiB) copied, 0.875302 s, 177 MB/s
INFO: Erasing: [/dev/mmcblk0] complete
INFO: [/bin/bash /opt/u-boot/bb-u-boot-beagleboneai64/install-emmc.sh]
Changing ext_csd[BOOT_BUS_CONDITIONS] from 0x02 to 0x02
H/W Reset is already permanently enabled on /dev/mmcblk0
Clearing eMMC boot0
dd if=/dev/zero of=/dev/mmcblk0boot0 count=32 bs=128k
32+0 records in
32+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.545392 s, 7.7 MB/s
dd if=/opt/u-boot/bb-u-boot-beagleboneai64/tiboot3.bin of=/dev/mmcblk0boot0 bs=128k
2+1 records in
2+1 records out
283940 bytes (284 kB, 277 KiB) copied, 1.13096 s, 251 kB/s
INFO: Partitioning: /dev/mmcblk0
INFO: /sbin/sfdisk: [sfdisk from util-linux 2.36.1]
INFO: /sbin/sfdisk: [/sbin/sfdisk --force /dev/mmcblk0]
INFO: /sbin/sfdisk: [1M,128M,0xc,*]
INFO: /sbin/sfdisk: [129M,,,-]
Checking that no-one is using this disk right now ... OK
Disk /dev/mmcblk0: 14.6 GiB, 15678308352 bytes, 30621696 sectors
Units: sectors of 1 * 512 = 512 bytes
>>> Created a new DOS disklabel with disk identifier 0x15723759.
/dev/mmcblk0p1: Created a new partition 1 of type 'W95 FAT32 (LBA)' and of size 128 MiB.
/dev/mmcblk0p2: Created a new partition 2 of type 'Linux' and of size 14.5 GiB.
/dev/mmcblk0p3: Done.
New situation:
Disklabel type: dos
Disk identifier: 0x15723759
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 * 2048 264191 262144 128M c W95 FAT32 (LBA)
/dev/mmcblk0p2 264192 30621695 30357504 14.5G 83 Linux
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
INFO: Formatting: /dev/mmcblk0
/sbin/mkfs.vfat -F 16 /dev/mmcblk0p1 -n FIRMWARE
mkfs.fat 4.2 (2021-01-31)
/sbin/mkfs.ext4 /dev/mmcblk0p2 -L rootfs
mke2fs 1.46.2 (28-Feb-2021)
Discarding device blocks: done
Creating filesystem with 3794688 4k blocks and 950272 inodes
Filesystem UUID: 77d47938-a59f-4afb-920f-c72d3d006f34
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
INFO: Formatting: /dev/mmcblk0 complete
Copying: /dev/mmcblk1p1 -> /dev/mmcblk0p1
rsync: /boot/firmware/ -> /tmp/boot/
INFO: [/boot/extlinux/extlinux.conf]
'/opt/u-boot/bb-u-boot-beagleboneai64/emmc-extlinux.conf' -> '/tmp/boot/extlinux/extlinux.conf'
INFO: [cat /tmp/boot/extlinux/extlinux.conf]
label Linux eMMC
kernel /Image
append console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait net.ifnames=0
fdtdir /
initrd /initrd.img
INFO: Copying: /dev/mmcblk1p2 -> /dev/mmcblk0p2
INFO: [mount /dev/mmcblk0p2 /tmp/rootfs/ -o async,noatime]
INFO: /usr/bin/rsync: [/ -> /tmp/rootfs/]
9.20G 99% 19.61MB/s 0:07:27 (xfr#160739, to-chk=0/187310)
INFO: Copying: Kernel modules
INFO: /usr/bin/rsync: /lib/modules/5.10.120-ti-arm64-r55/ -> /tmp/rootfs/lib/modules/5.10.120-ti-arm64-r55/
31.06M 100% 14.26MB/s 0:00:02 (xfr#2468, to-chk=0/2917)
INFO: Generating: /etc/fstab
INFO: [cat /tmp/rootfs/etc/fstab]
# /etc/fstab: static file system information.
/dev/mmcblk0p2 / ext4 noatime,errors=remount-ro 0 1
/dev/mmcblk0p1 /boot/firmware vfat defaults 0 0
debugfs /sys/kernel/debug debugfs mode=755,uid=root,gid=gpio,defaults 0 0
INFO: [cp -v /etc/beagle-flasher/bbai64-emmc-to-microsd /tmp/rootfs/etc/default/beagle-flasher]
'/etc/beagle-flasher/bbai64-emmc-to-microsd' -> '/tmp/rootfs/etc/default/beagle-flasher'
INFO: [cat /tmp/rootfs/etc/default/generic-sys-mods]
#This file is sourced by /usb/bin/bb-growpart
ROOT_DRIVE=/dev/mmcblk0
ROOT_PARTITION=2
Copying: /dev/mmcblk1p2 -> /dev/mmcblk0p2 complete
INFO: [umount /tmp/rootfs/ || umount -l /tmp/rootfs/ || write_failure]
INFO: Force writeback of eMMC buffers by Syncing: /dev/mmcblk0
INFO: [dd if=/dev/mmcblk0 of=/dev/null count=100000 status=progress]
100000+0 records in
100000+0 records out
51200000 bytes (51 MB, 49 MiB) copied, 0.345683 s, 148 MB/s
/usr/sbin/beagle-flasher: line 89: echo: write error: Invalid argument
root@yantrr:~#
Did I miss any step while generating boot image using omap-image-builder?
Any solution to resolve this issue?
