I’m wondering if I may have a hardware issue here, maybe someone would know what to check.
I have been using SD cards while messing around with anything that may cause problems with booting.
I have tried 4 cards, all good quality and am getting problems booting from the cards, sometimes fine, mostly issues.
The first sign of problems is an issue reading the status registerL
[ 5.866556] Run /init as init process
[ 5.873641] mmc1: problem reading SD Status register
Loading, please wait...
then it goes to pot
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
[ 14.070272] mmc1: error -110 whilst initialising SD card
[ 14.552510] mmc1: error -110 whilst initialising SD card
[ 15.044409] mmc1: error -110 whilst initialising SD card
[ 15.549037] mmc1: error -110 whilst initialising SD card
done.
Gave up waiting for root file system device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/mmcblk1p2 does not exist. Dropping to a shell!
or here is another card:
[ 5.846131] mmc1: new ultra high speed DDR50 SDHC card at address 0001
[ 5.853209] mmcblk1: mmc1:0001 00000 29.3 GiB
[ 5.858906] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.868417] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.874839] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.881260] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.887681] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.894101] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 5.900522] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.906943] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.913363] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 5.919783] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.926203] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 5.932625] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.939045] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.945466] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x00ea3f7f
[ 5.951886] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 5.958306] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.962733] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089511420c
[ 5.969848] mmc1: sdhci: ============================================
[ 5.978673] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.987265] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.993686] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.000107] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.006528] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.012950] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 6.019370] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.025791] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 6.032211] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.038631] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.045051] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 6.051471] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.057892] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.064312] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x00ea3f7f
[ 6.070734] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 6.077154] mmc1: sdhci: Host ctl2: 0x0000000c
[ 6.081582] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089511420c
[ 6.088696] mmc1: sdhci: ============================================
Starting version 247.3-7
[ 6.266354] mmc1: tried to HW reset card, got error -84
[ 6.275404] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6.289266] blk_update_request: I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6.303076] blk_update_request: I/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6.316938] blk_update_request: I/O error, dev mmcblk1, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6.330774] blk_update_request: I/O error, dev mmcblk1, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6.344622] blk_update_request: I/O error, dev mmcblk1, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6.358441] blk_update_request: I/O error, dev mmcblk1, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6.372247] blk_update_request: I/O error, dev mmcblk1, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6.382463] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 6.393641] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.402235] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.408657] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.415078] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.421499] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.427920] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b
[ 6.434341] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.440762] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07
[ 6.447183] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 6.453605] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.460026] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 6.466448] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.472868] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.479289] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x30101bcb
[ 6.485710] mmc1: sdhci: Resp[2]: 0x30303030 | Resp[3]: 0x00000900
[ 6.492130] mmc1: sdhci: Host ctl2: 0x00000008
[ 6.496558] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089511420c
[ 6.503672] mmc1: sdhci: ============================================
[ 6.514436] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.523031] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.529453] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.535876] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.542298] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.548719] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b
[ 6.555141] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.561562] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07
[ 6.567982] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 6.574403] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.580824] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 6.587244] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.593665] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.600086] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x30101bcb
[ 6.606506] mmc1: sdhci: Resp[2]: 0x30303030 | Resp[3]: 0x00000900
[ 6.612927] mmc1: sdhci: Host ctl2: 0x00000008
[ 6.617355] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089511420c
[ 6.624468] mmc1: sdhci: ============================================
[ 6.634872] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6.648679] blk_update_request: I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 6.680489] Buffer I/O error on dev mmcblk1, logical block 0, async page read
I have loaded the cards up on a ubuntu machine and checked the filesystems, no problems.
Anyone any ideas?
