Hi Guys,
So I am at the stage where I can get the Image
loaded into kernel_addr
and the DTB
loaded into fdt_addr
Does anyone know how to boot this up know, I’m banging my head against the wall!
Hi Guys,
and the DTB
at the very least you need something like
bootz 0x80800000 - 0x83000000;
This is taken form an imx6ul boot I have. the first address is the kernel address, the last address that of the devicetree. These will of course be different. Can’t for the life of me remember why the ‘-’ inbetween
Hi Benedict,
Thanks for the info.
I did try using {kernel_addr} - {ftd_addr} but I think I tried bootm rather than bootz, I will give bootz a go today…
if it is a zImage then pretty sure you need to use bootz.
Right had a look there is no bootz
, I was using booti
but I was using mistyped variable names and it doesn’t seem to worry about that!
tftp $kernel_addr_r Image
tftp $fdtaddr k3-j721e-beagleboneai64.dtb
booti $kernel_addr_r - $fdtaddr
It is now booting the kernel and then falling over
There are a load of scripts that seem to run out of the env vars, I’m guessing I need to shoehorn something into them somehow.
Thanks for the help, got me one step further
addr_fit=0x90000000
arch=arm
args_all=setenv optargs earlycon=ns16550a,mmio32,0x02800000 ${mtdparts}
args_mmc=run finduuid;setenv bootargs console=${console} ${optargs} root=PARTUUID=${uuid} rw rootfstype=${mmcrootfstype}
args_ufs=setenv devtype scsi;setenv bootpart 1:1;run ufs_finduuid;setenv bootargs console = ${console} ${optargs}root=PARTUUID=${uuid} rw rootfstype=${scsirootfstype};setenv devtype scsi;setenv bootpart 1:1
baudrate=115200
board=j721e
board_name=BBONEAI-64-B0-
board_rev=B0
board_serial=0053
board_software_revision=01
boot=mmc
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_efi_bootmgr=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_fdt=try
boot_fit=0
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_rprocs=if test ${dorprocboot} -eq 1 && test ${boot} = mmc; then rproc init;run boot_rprocs_mmc;fi;
boot_rprocs_mmc=env set rproc_id;env set rproc_fw;for i in ${rproc_fw_binaries} ; do if test -z "${rproc_id}" ; then env set rproc_id $i;else env set rproc_fw $i;run rproc_load_and_boot_one;env set rproc_id;env set rproc_fw;fi;done
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=mmc1 mmc0 pxe dhcp
bootcmd=run findfdt; run distro_bootcmd; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern
bootcmd_dhcp=setenv devtype dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_mmc0=devnum=0; run mmc_boot
bootcmd_mmc1=devnum=1; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootdelay=2
bootdir=/boot
bootenvfile=uEnv.txt
bootm_size=0x10000000
bootpart=1:2
bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr}
console=ttyS2,115200n8
cpu=armv8
default_device_tree=k3-j721e-beagleboneai64.dtb
dfu_alt_info_emmc=rawemmc raw 0 0x800000 mmcpart 1;rootfs part 0 1 mmcpart 0;tiboot3.bin.raw raw 0x0 0x400 mmcpart 1;tispl.bin.raw raw 0x400 0x1000 mmcpart 1;u-boot.img.raw raw 0x1400 0x2000 mmcpart 1;u-env.raw raw 0x3400 0x100 mmcpart 1;sysfw.itb.raw raw 0x3600 0x800 mmcpart 1
dfu_alt_info_mmc=boot part 1 1;rootfs part 1 2;tiboot3.bin fat 1 1;tispl.bin fat 1 1;u-boot.img fat 1 1;uEnv.txt fat 1 1;sysfw.itb fat 1 1
dfu_alt_info_ospi=tiboot3.bin raw 0x0 0x080000;tispl.bin raw 0x080000 0x200000;u-boot.img raw 0x280000 0x400000;u-boot-env raw 0x680000 0x020000;sysfw.itb raw 0x6c0000 0x100000;rootfs raw 0x800000 0x3800000
dfu_alt_info_ram=tispl.bin ram 0x80080000 0x200000;u-boot.img ram 0x81000000 0x400000
distro_bootcmd=scsi_need_init=; for target in ${boot_targets}; do run bootcmd_${target}; done
dorprocboot=0
dtboaddr=0x89000000
eeprom_bbai_erase=i2c dev 0; i2c md 0x51 0x00.1 40; i2c mw 0x51 0x00.1 ff; i2c mw 0x51 0x01.1 ff; i2c mw 0x51 0x02.1 ff; i2c mw 0x51 0x03.1 ff; i2c mw 0x51 0x04.1 ff; i2c mw 0x51 0x05.1 ff; i2c mw 0x51 0x06.1 ff; i2c mw 0x51 0x07.1 ff; i2c mw 0x51 0x08.1 ff; i2c mw 0x51 0x09.1 ff; i2c mw 0x51 0x0a.1 ff; i2c mw 0x51 0x0b.1 ff; i2c mw 0x51 0x0c.1 ff; i2c mw 0x51 0x0d.1 ff; i2c mw 0x51 0x0e.1 ff; i2c mw 0x51 0x0f.1 ff; i2c mw 0x51 0x10.1 ff; i2c mw 0x51 0x11.1 ff; i2c mw 0x51 0x12.1 ff; i2c mw 0x51 0x13.1 ff; i2c mw 0x51 0x14.1 ff; i2c mw 0x51 0x15.1 ff; i2c mw 0x51 0x16.1 ff; i2c mw 0x51 0x17.1 ff; i2c mw 0x51 0x18.1 ff; i2c mw 0x51 0x19.1 ff; i2c mw 0x51 0x1a.1 ff; i2c mw 0x51 0x1b.1 ff; i2c mw 0x51 0x1c.1 ff; i2c mw 0x51 0x1d.1 ff; i2c mw 0x51 0x1e.1 ff; i2c mw 0x51 0x1f.1 ff; i2c mw 0x51 0x20.1 ff; i2c mw 0x51 0x21.1 ff; i2c mw 0x51 0x22.1 ff; i2c mw 0x51 0x23.1 ff; i2c mw 0x51 0x24.1 ff; i2c mw 0x51 0x25.1 ff; i2c mw 0x51 0x26.1 ff; i2c mw 0x51 0x27.1 ff; i2c mw 0x51 0x28.1 ff; i2c mw 0x51 0x29.1 ff; i2c mw 0x51 0x2a.1 ff; i2c mw 0x51 0x2b.1 ff; i2c mw 0x51 0x2c.1 ff; i2c mw 0x51 0x2d.1 ff; i2c mw 0x51 0x2e.1 ff; i2c mw 0x51 0x2f.1 ff; i2c mw 0x51 0x30.1 ff; i2c mw 0x51 0x31.1 ff; i2c mw 0x51 0x32.1 ff; i2c mw 0x51 0x33.1 ff; i2c mw 0x51 0x34.1 ff; i2c mw 0x51 0x35.1 ff; i2c mw 0x51 0x36.1 ff; i2c mw 0x51 0x37.1 ff; i2c mw 0x51 0x38.1 ff; i2c mw 0x51 0x39.1 ff; i2c mw 0x51 0x3a.1 ff; i2c mw 0x51 0x3b.1 ff; i2c mw 0x51 0x3c.1 ff; i2c mw 0x51 0x3d.1 ff; i2c mw 0x51 0x3e.1 ff; i2c mw 0x51 0x3f.1 ff; i2c md 0x51 0x00.1 40;
eeprom_dump=i2c dev 0; i2c md 0x51 0x00.1 40;
eeprom_production_bbai=i2c dev 0; i2c md 0x51 0x00.1 40; i2c mw 0x51 0x00.1 aa; i2c mw 0x51 0x01.1 55; i2c mw 0x51 0x02.1 33; i2c mw 0x51 0x03.1 ee; i2c mw 0x51 0x04.1 01; i2c mw 0x51 0x05.1 37; i2c mw 0x51 0x06.1 00; i2c mw 0x51 0x07.1 10; i2c mw 0x51 0x08.1 2e; i2c mw 0x51 0x09.1 00; i2c mw 0x51 0x0a.1 42; i2c mw 0x51 0x0b.1 42; i2c mw 0x51 0x0c.1 4f; i2c mw 0x51 0x0d.1 4e; i2c mw 0x51 0x0e.1 45; i2c mw 0x51 0x0f.1 41; i2c mw 0x51 0x10.1 49; i2c mw 0x51 0x11.1 2d; i2c mw 0x51 0x12.1 36; i2c mw 0x51 0x13.1 34; i2c mw 0x51 0x14.1 2d; i2c mw 0x51 0x15.1 42; i2c mw 0x51 0x16.1 30; i2c mw 0x51 0x17.1 2d; i2c mw 0x51 0x18.1 00; i2c mw 0x51 0x19.1 00; i2c mw 0x51 0x1a.1 42; i2c mw 0x51 0x1b.1 30; i2c mw 0x51 0x1c.1 30; i2c mw 0x51 0x1d.1 30; i2c mw 0x51 0x1e.1 37; i2c mw 0x51 0x1f.1 38; i2c mw 0x51 0x20.1 30; i2c mw 0x51 0x21.1 31; i2c mw 0x51 0x22.1 42; i2c mw 0x51 0x23.1 30; i2c mw 0x51 0x24.1 30; i2c mw 0x51 0x25.1 30; i2c mw 0x51 0x26.1 30; i2c mw 0x51 0x27.1 31; i2c mw 0x51 0x28.1 36; i2c mw 0x51 0x29.1 34; i2c mw 0x51 0x2a.1 57; i2c mw 0x51 0x2b.1 57; i2c mw 0x51 0x2c.1 32; i2c mw 0x51 0x2d.1 32; i2c mw 0x51 0x2e.1 42; i2c mw 0x51 0x2f.1 42; i2c mw 0x51 0x30.1 42; i2c mw 0x51 0x31.1 42; i2c mw 0x51 0x32.1 42; i2c mw 0x51 0x33.1 42; i2c mw 0x51 0x34.1 53; i2c mw 0x51 0x35.1 53; i2c mw 0x51 0x36.1 53; i2c mw 0x51 0x37.1 53; i2c mw 0x51 0x38.1 11; i2c mw 0x51 0x39.1 02; i2c mw 0x51 0x3a.1 00; i2c mw 0x51 0x3b.1 60; i2c mw 0x51 0x3c.1 7d; i2c mw 0x51 0x3d.1 fe; i2c mw 0x51 0x3e.1 ff; i2c mw 0x51 0x3f.1 ff; i2c md 0x51 0x00.1 40;
efi_dtb_prefixes=/ /dtb/ /dtb/current/
emmc_erase_boot0=mmc dev 0 1; mmc erase 0 0x2400;
envboot=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootscript; then run bootscript;else if run loadbootenv; then echo Loaded env from ${bootenvfile};run importbootenv;fi;if test -n $uenvcmd; then echo Running uenvcmd ...;run uenvcmd;fi;fi;fi;
ethact=ethernet@46000000
ethaddr=24:76:25:a0:f0:de
fdt_addr_r=0x88000000
fdtaddr=0x88000000
fdtcontroladdr=fdec0ed0
fdtoverlay_addr_r=0x80200000
fileaddr=82000000
filesize=31523
findfdt=echo board_name=[$board_name] ...;setenv name_fdt ${default_device_tree};if test $board_name = J721EX-PM1-SOM; then setenv name_fdt k3-j721e-proc-board-tps65917.dtb; elif test $board_name = J721EX-PM2-SOM; then setenv name_fdt k3-j721e-common-proc-board.dtb; elif test $board_name = BBONEAI-64-B0-; then setenv name_fdt k3-j721e-beagleboneai64.dtb; elif test $board_name = j721e; then setenv name_fdt k3-j721e-common-proc-board.dtb; elif test $board_name = j721e-eaik || test $board_name = j721e-sk; then setenv name_fdt k3-j721e-sk.dtb; else setenv name_fdt k3-j721e-beagleboneai64.dtb; fi; echo name_fdt=[${name_fdt}] ...;setenv fdtfile ${name_fdt}
finduuid=part uuid ${boot} ${bootpart} uuid
get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt}
get_fdt_ufs=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}
get_fit_mmc=load mmc ${bootpart} ${addr_fit} ${bootdir}/${name_fit}
get_kern_mmc=load mmc ${bootpart} ${loadaddr} ${bootdir}/${name_kern}
get_kern_ufs=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${name_kern}
get_overlay_mmc=fdt address ${fdtaddr};fdt resize 0x100000;for overlay in $name_overlays;do;load mmc ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && fdt apply ${dtboaddr};done;
get_overlay_ufs=fdt address ${fdtaddr};fdt resize 0x100000;for overlay in $name_overlays;do;load scsi ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && fdt apply ${dtboaddr};done;
get_overlaystring=for overlay in $name_overlays;do;setenv overlaystring ${overlaystring}'#'${overlay};done;
importbootenv=echo Importing environment from mmc${mmcdev} ...; env import -t ${loadaddr} ${filesize}
init_mmc=run args_all args_mmc
init_ufs=ufs init; scsi scan; run args_ufs
ipaddr=192.168.0.164
kernel_addr_r=0x82000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
loadaddr=0x82000000
loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenvfile}
loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr
loadfdt=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}
loadimage=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
mmcboot=mmc dev ${mmcdev}; devnum=${mmcdev}; devtype=mmc; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadimage; then run args_mmc; if test ${boot_fit} -eq 1; then run run_fit; else run mmcloados;fi;fi;fi;
mmcdev=1
mmcloados=if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdtaddr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
mmcrootfstype=ext4 rootwait
mtdids=nor0=47040000.spi.0,nor0=47034000.hyperbus
mtdparts=mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs)
name_fit=fitImage
name_kern=Image
partitions=uuid_disk=${uuid_gpt_disk};name=rootfs,start=0,size=-,uuid=${uuid_gpt_rootfs}
pxefile_addr_r=0x80100000
ramdisk_addr_r=0x88080000
rd_spec=-
rdaddr=0x88080000
rproc_fw_binaries=2 /lib/firmware/j7-main-r5f0_0-fw 3 /lib/firmware/j7-main-r5f0_1-fw 4 /lib/firmware/j7-main-r5f1_0-fw 5 /lib/firmware/j7-main-r5f1_1-fw 6 /lib/firmware/j7-c66_0-fw 7 /lib/firmware/j7-c66_1-fw 8 /lib/firmware/j7-c71_0-fw
rproc_load_and_boot_one=if load mmc ${bootpart} $loadaddr ${rproc_fw}; then if rproc load ${rproc_id} ${loadaddr} ${filesize}; then rproc start ${rproc_id};fi;fi
run_fit=bootm ${addr_fit}#${fdtfile}${overlaystring}
run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;run boot_efi_bootmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x80000000
scsi_boot=run scsi_init; if scsi dev ${devnum}; then devtype=scsi; run scan_dev_for_boot_part; fi
scsi_init=if ${scsi_need_init}; then scsi_need_init=false; scsi scan; fi
scsirootfstype=ext4 rootwait
serial#=0000000000000053
serverip=192.168.0.149
soc=k3
stderr=serial@2800000
stdin=serial@2800000
stdout=serial@2800000
ufs_finduuid=part uuid scsi ${bootpart} uuid
update_to_fit=setenv loadaddr ${addr_fit}; setenv bootfile ${name_fit}
usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
vendor=ti
And this is where it goes wrong:
[ 5.918893] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[ 5.926367] Please append a correct "root=" boot option; here are the available partitions:
sounds like you are not setting up bootargs before booting the kernel.
The kernel should print its command line args very early. Can you see if anything is set ?
Thanks for the help.
You were absolutely correct, here was no boot args stuff, after a bit of fiddling it is booting:
run init_mmc
