and strace return this:
-bash-4.2# strace aplay balle_1.wav
execve("/usr/bin/aplay", [“aplay”, “balle_1.wav”], [/* 13 vars /]) = 0
brk(0) = 0x1e000
uname({sys=“Linux”, node=“EmoxBeaglebone”, …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x400a0000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=46153, …}) = 0
mmap2(NULL, 46153, PROT_READ, MAP_PRIVATE, 3, 0) = 0x4011b000
close(3) = 0
open("/lib/librt.so.1", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\320\26\0\0004\0\0\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=39206, …}) = 0
mmap2(NULL, 57876, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x401cb000
mprotect(0x401d1000, 28672, PROT_NONE) = 0
mmap2(0x401d8000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5) = 0x401d8000
close(3) = 0
open("/usr/lib/libasound.so.2", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\340\324\1\0004\0\0\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1412894, …}) = 0
mmap2(NULL, 1158352, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x401da000
mprotect(0x402ea000, 28672, PROT_NONE) = 0
mmap2(0x402f1000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10f) = 0x402f1000
close(3) = 0
open("/lib/libm.so.6", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\3301\0\0004\0\0\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=499795, …}) = 0
mmap2(NULL, 467112, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x40127000
mprotect(0x40191000, 28672, PROT_NONE) = 0
mmap2(0x40198000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x69) = 0x40198000
close(3) = 0
open("/lib/libdl.so.2", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\374\10\0\0004\0\0\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=14360, …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x400ca000
mmap2(NULL, 41136, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x402f5000
mprotect(0x402f7000, 28672, PROT_NONE) = 0
mmap2(0x402fe000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1) = 0x402fe000
close(3) = 0
open("/lib/libpthread.so.0", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0PE\0\0004\0\0\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=131643, …}) = 0
mmap2(NULL, 127508, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x400a9000
mprotect(0x400be000, 28672, PROT_NONE) = 0
mmap2(0x400c5000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14) = 0x400c5000
mmap2(0x400c7000, 4628, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x400c7000
close(3) = 0
open("/lib/libgcc_s.so.1", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0p&\0\0004\0\0\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=173334, …}) = 0
mmap2(NULL, 70176, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x400cb000
mprotect(0x400d4000, 32768, PROT_NONE) = 0
mmap2(0x400dc000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9) = 0x400dc000
close(3)open("/lib/libc.so.6", O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0P^\1\0004\0\0\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1571032, …}) = 0
mmap2(NULL, 1283336, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x40300000
mprotect(0x4042c000, 32768, PROT_NONE) = 0
mmap2(0x40434000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12c) = 0x40434000
mmap2(0x40437000, 9480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40437000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4005a000
set_tls(0x4005a810, 0x400a8918, 0x4005aee8, 0x4005a810, 0x400a8000) = 0
mprotect(0x40300000, 1228800, PROT_READ|PROT_WRITE) = 0
mprotect(0x40300000, 1228800, PROT_READ|PROT_EXEC) = 0
cacheflush(0x40300000, 0x4042c000, 0, 0x15, 0x400ca7e8) = 0
mprotect(0x40434000, 8192, PROT_READ) = 0
mprotect(0x400c5000, 4096, PROT_READ) = 0
mprotect(0x402fe000, 4096, PROT_READ) = 0
mprotect(0x40198000, 4096, PROT_READ) = 0
mprotect(0x401cb000, 24576, PROT_READ|PROT_WRITE) = 0
mprotect(0x401cb000, 24576, PROT_READ|PROT_EXEC) = 0
cacheflush(0x401cb000, 0x401d1000, 0, 0x15, 0x400a0650) = 0
mprotect(0x401d8000, 4096, PROT_READ) = 0
mprotect(0x400a7000, 4096, PROT_READ) = 0
munmap(0x4011b000, 46153) = 0
set_tid_address(0x4005a3b8) = 1007
set_robust_list(0x4005a3c0, 12) = 0
futex(0xbe817d94, FUTEX_WAIT_BITSET_PRIVATE|FUTEX_CLOCK_REALTIME, 1, NULL, 400c6000) = -1 EAGAIN (Resource temporarily unavailable)
rt_sigaction(SIGRTMIN, {0x400ad0c4, [], SA_SIGINFO|0x4000000}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x400acf6c, [], SA_RESTART|SA_SIGINFO|0x4000000}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=81921024, rlim_max=RLIM_INFINITY}) = 0
brk(0) = 0x1e000
brk(0x3f000) = 0x3f000
stat64("/usr/share/alsa/alsa.conf", {st_mode=S_IFREG|0644, st_size=9184, …}) = 0
open("/usr/share/alsa/alsa.conf", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=9184, …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x400fe000
read(3, “#\n# ALSA library configuration “…, 4096) = 4096
read(3, “@args [ CARD DEV SUBDEV ]\n\t@args”…, 4096) = 4096
read(3, “query.hw {\n\ttype hw\n}\n\ntimer.def”…, 4096) = 992
read(3, “”, 4096) = 0
close(3) = 0
munmap(0x400fe000, 4096) = 0
futex(0x402ff0a4, FUTEX_WAKE_PRIVATE, 2147483647) = 0
access(”/usr/share/alsa/alsa.conf.d/”, R_OK) = 0
stat64("/usr/share/alsa/alsa.conf.d/", {st_mode=S_IFDIR|0755, st_size=4096, …}) = 0
open("/usr/share/alsa/alsa.conf.d/", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY|O_CLOEXEC) = 3
fcntl64(3, F_GETFD) = 0x1 (flags FD_CLOEXEC)
getdents(3, /* 3 entries /, 32768) = 52
getdents(3, / 0 entries */, 32768) = 0
close(3) = 0
access("/etc/asound.conf", R_OK) = -1 ENOENT (No such file or directory)
access("/root/.asoundrc", R_OK) = -1 ENOENT (No such file or directory)
stat64("/usr/share/alsa/cards/aliases.conf", {st_mode=S_IFREG|0644, st_size=1405, …}) = 0
open("/usr/share/alsa/cards/aliases.conf", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=1405, …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4003b000
read(3, “#\n# Define aliases for various “…, 4096) = 1405
open(”/usr/share/alsa/pcm/default.conf”, O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=762, …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x400ec000
read(4, “#\n# Default output\n#\n\npcm.!defau”…, 4096) = 762
read(4, “”, 4096) = 0
close(4) = 0
munmap(0x400ec000, 4096) = 0
open("/usr/share/alsa/pcm/dmix.conf", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=1517, …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x400dd000
read(4, “#\n# dmix output\n#\n\npcm.!dmix {\n\t”…, 4096) = 1517
close(4) = 0
munmap(0x400dd000, 4096) = 0
open("/usr/share/alsa/pcm/dsnoop.conf", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=1532, …}) = 0
read(4, “#\n# dsnoop\n#\n\npcm.!dsnoop {\n\t@ar”…, 4096) = 1532
close(4) = 0
close(3) = 0
munmap(0x4003b000, 4096) = 0
— SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x35} —
+++ killed by SIGSEGV +++
Segmentation fault
