while waiting for a fresh pot of coffee, i'll ponder a bit more on
some of the untidiness i found related to deselecting NAND for the
beagle xm. not so much looking for a solution as thinking out loud.
in my earlier experiment, simply undefining the symbol
CONFIG_CMD_NAND didn't deselect all NAND functionality. for example,
i got in trouble here in the source file
arch/arm/cpu/armv7/omap3/board.c:
#if defined(CONFIG_NAND_OMAP_GPMC) & !defined(CONFIG_SPL_BUILD)
* OMAP3 specific command to switch between NAND HW and SW ecc
static int do_switch_ecc(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[])
if (argc != 2)
goto usage;
if (strncmp(argv[1], "hw", 2) == 0)
omap_nand_switch_ecc(1);
else if (strncmp(argv[1], "sw", 2) == 0)
omap_nand_switch_ecc(0);
else
goto usage;
return 0;
usage:
printf ("Usage: nandecc %s\n", cmdtp->usage);
return 1;
the problem is that, even though CONFIG_CMD_NAND was undefined, the
symbol CONFIG_NAND_OMAP_GPMC is defined independently in the config
file include/configs/omap3_beagle.h:
* Board NAND Info.
#define CONFIG_SYS_NAND_QUIET_TEST 1
#define CONFIG_NAND_OMAP_GPMC
... and so on ...
so the build attempts to compile a routine which itself no longer
exists (omap_nand_switch_ecc) because of a lack of proper dependencies
between those symbols.
one solution would be to properly surround chunks in the
omap3_beagle.h file with, for example:
#ifdef CONFIG_CMD_NAND
... all NAND-related stuff ...
#endif
that would certainly clean up *some* of the mess.
a second issue is what something like "CONFIG_CMD_NAND" even
*means*. in the top-level README file, there is:
CONFIG_CMD_NAND * NAND support
well, no, that's not what that means at all. there's a real
difference in whether a feature is *supported* in u-boot, and whether
you're selecting to build in its *command*. theoretically, i might
not need command-line access to the "nand" subsystem, but i might
still need access to it *programatically* from other parts of u-boot.
i'd never actually noticed this before, and i'm sure i'm not the
first person who's tripped over this. does this make sense?
thoughts?
rday
