It is mostly as this VGA thing dont want to cooperate, after testing several methods without any effective results (== display converted to VGA output), Im currently testing the VGA adapter made of resistor ladders (and a couple of sync logic inverters using npn transistors) from this page:
http://www.linusakesson.net/hardware/beagleboard/vga.php
Im sure this is very familiar for BB C4 users (from the number of threads and web pages that are related to this vga method), so here is my question, Have anyone tested this on a BB xM?
I have constructed this adapter, and verified again and again that all connections, traces, and components are properly soldered, but the BeagleBoard (xM) simply dont want to boot when this adapter is connected to the LCD expansion port (not even any serial output), after the power is applied, it simply lit some of the leds, but nothing after that
I have purchased the same resitors that are used in that page (after a month and a half of shipping and delivery time) 60.4 omhs and 121 omhs, low tolerance, metal-film type
Is it because the outputs (lcd data bits) are conencted to the ladder that draws 7.5 mA? and the nominal current of the pin is only 0.1mA? but this has not prevented the C4 from working with this adapter
I even have have connected the BB directly to the PC power supply (5v rail) that can provide 8 ~ 10A (more than enough for the BB)
As soon as the adapter is disconnected, the BB boots up
I have reviewed several times, there are no shorts or other issues
Ok, if this method dont work, I suppose we have the active DVI to VGA converter from fit-PC or some Asian DVI-VGA converter (there is a $24 unit that seems to work ok as per the reviews)
Lioric
