Sorry, here’s the full output:
U-Boot SPL 2013.04-rc1-14237-g90639fe-dirty (Apr 13 2013 - 13:57:11)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-rc1-14237-g90639fe-dirty (Apr 13 2013 - 13:57:11)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
226 bytes read in 3 ms (73.2 KiB/s)
Running uenvcmd …
reading uImage
3687224 bytes read in 447 ms (7.9 MiB/s)
Booting kernel from Legacy Image at 81000000 …
Image Name: Linux-3.2.0-gfe511cc
Data Size: 3687160 Bytes = 3.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
[ 0.000000] Linux version 3.2.0-gfe511cc (x0146275@psplinux052) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 Fri Aug 17 12:18:40 IST 2012
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait rootdelay=1 init=/init ip=off
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 251280k/251280k available, 10864k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0694000 (6704 kB)
[ 0.000000] .init : 0xc0694000 - 0xc06d2000 ( 248 kB)
[ 0.000000] .data : 0xc06d2000 - 0xc072e440 ( 370 kB)
[ 0.000000] .bss : 0xc072e464 - 0xc085f888 (1222 kB)
[ 0.000000] NR_IRQS:396
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000183] Calibrating delay loop… 548.86 BogoMIPS (lpj=2744320)
[ 0.048309] pid_max: default: 32768 minimum: 301
[ 0.048461] Security Framework initialized
[ 0.048522] Mount-cache hash table entries: 512
[ 0.048950] CPU: Testing write buffer coherency: ok
[ 0.069763] omap_hwmod: pruss: failed to hardreset
[ 0.070678] print_constraints: dummy:
[ 0.070922] NET: Registered protocol family 16
[ 0.072204] OMAP GPIO hardware version 0.1
[ 0.073486] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.074951] omap_i2c.1: alias fck already exists
[ 0.075561] omap2_mcspi.1: alias fck already exists
[ 0.075683] omap2_mcspi.2: alias fck already exists
[ 0.075897] edma.0: alias fck already exists
[ 0.075927] edma.0: alias fck already exists
[ 0.088073] bio: create slab at 0
[ 0.089263] SCSI subsystem initialized
[ 0.090240] usbcore: registered new interface driver usbfs
[ 0.090393] usbcore: registered new interface driver hub
[ 0.090515] usbcore: registered new device driver usb
[ 0.090667] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[ 0.090850] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[ 0.091400] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.092346] tps65910 1-002d: could not be detected
[ 0.092926] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.093597] Bluetooth: Core ver 2.16
[ 0.093658] NET: Registered protocol family 31
[ 0.093688] Bluetooth: HCI device and connection manager initialized
[ 0.093688] Bluetooth: HCI socket layer initialized
[ 0.093719] Bluetooth: L2CAP socket layer initialized
[ 0.093750] Bluetooth: SCO socket layer initialized
[ 0.093994] Switching to clocksource gp timer
[ 0.103912] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.104156] musb-hdrc musb-hdrc.0: dma type: pio
[ 0.104370] MUSB0 controller’s USBSS revision = 4ea20800
[ 0.104949] musb-hdrc musb-hdrc.0: USB OTG mode controller at d083c000 using PIO, IRQ 18
[ 0.105194] musb-hdrc musb-hdrc.1: dma type: pio
[ 0.105407] MUSB1 controller’s USBSS revision = 4ea20800
[ 0.105529] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.105621] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.105773] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.105773] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.105804] usb usb1: Product: MUSB HDRC host driver
[ 0.105804] usb usb1: Manufacturer: Linux 3.2.0-gfe511cc musb-hcd
[ 0.105834] usb usb1: SerialNumber: musb-hdrc.1
[ 0.106506] hub 1-0:1.0: USB hub found
[ 0.106536] hub 1-0:1.0: 1 port detected
[ 0.106994] musb-hdrc musb-hdrc.1: USB Host mode controller at d083e800 using PIO, IRQ 19
[ 0.107360] NET: Registered protocol family 2
[ 0.107604] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.108032] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.108215] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.108337] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.108367] TCP reno registered
[ 0.108367] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.108398] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.108673] NET: Registered protocol family 1
[ 0.108978] RPC: Registered named UNIX socket transport module.
[ 0.109008] RPC: Registered udp transport module.
[ 0.109008] RPC: Registered tcp transport module.
[ 0.109008] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.109313] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.299285] ashmem: initialized
[ 0.299591] VFS: Disk quotas dquot_6.5.2
[ 0.299652] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.300689] msgmni has been set to 490
[ 0.301910] io scheduler noop registered
[ 0.301940] io scheduler deadline registered
[ 0.302001] io scheduler cfq registered (default)
[ 0.302703] Could not set LED4 to fully on
[ 0.303955] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.890106] console [ttyO0] enabled
[ 0.894195] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 0.901947] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 0.909667] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 0.917388] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 0.925109] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 0.940338] brd: module loaded
[ 0.947662] loop: module loaded
[ 0.951141] i2c-core: driver [tsl2550] using legacy suspend method
[ 0.957641] i2c-core: driver [tsl2550] using legacy resume method
[ 0.964080] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.024536] No daughter card found on AM335x EVM
[ 1.029418] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.044647] Board name: A335BNLT
[ 1.048004] Board version: 0A5A
[ 1.051269] SKU: ???
[ 1.053833] The error message above indicates that there is an issue with
[ 1.053863] the EEPROM or the EEPROM contents. After verifying the EEPROM
[ 1.053863] contents, if any, refer to the am335x_evm_setup function in the
[ 1.053863] arch/arm/mach-omap2/board-am335xevm.c file to modify the board
[ 1.053863] initialization code to match the hardware configuration
