Does anyone know if Android “fast boot” has been implemented (via u-boot?) for the BB-xM? I’ve been searching but not found anything of significance…
Richard,
Richard,
mainline u-boot has some fastboot support, but only for booting and not for flashing at this time. That’s probably OK for BB-xM since it doesn’t have persistent storage you can’t write from elsewhere. Is there something specific you’re looking for?
I was indeed hoping to have the flashing support also - it is possible to implement it, or do I need to forget about it?!
Well, if you pick up one of the android trees that supports bb-xM specifically it may have flashing support somehow hooked up for the SD card, I’ve not played with those trees.
Do you have a specific Android tree in mind, so I can check it out?
