I am using pre-built binaries from Texas Instruments Android Development Kit
Followed the mkmmc script to copy the files onto SD/MMC.
It is successfully booting from SD card and successful reboots as well.
In case of MMC, boots fine at very first time, could see all the folders got created and can execute 3D videos, storage perf apps. On reset and reboot, it could not see ext3 partition that leads to kernel panic. PC host also could not mount ext3 partition as it was corrupted. I need to reflash the MMC to boot again.
Free memory comparison SD vs MMC:
After successful booting,
SD boot: shows about 50MB free space out of total 256MB
MMC boot: shows about 7MB free space
Suspect memory leak in MMC flow path.
Did anyone come across this issue with pre-built binary? Is there any patch ?
Muthu
No I have done the same but I do not se the issue
Sorry
Victor Rodriguez
Thanks for response.
Which make of MMC and is it MMC 4.3 or 4.4 version ? What is the size of the MMC storage ?
Muthu
— On Thu, 12/2/10, Victor Rodriguez vm.rod25@gmail.com wrote:
> From: Victor Rodriguez vm.rod25@gmail.com
> Subject: Re: [beagleboard] Android Froyo on Beagleboard, MMC ext3 filesystem corrupted after first successful boot
> To: beagleboard@googlegroups.com
> Date: Thursday, December 2, 2010, 10:40 PM
> On Thu, Dec 2, 2010 at 12:05 PM, Muthukumar karuppiah kmkr3@yahoo.com wrote:
> > I am using pre-built binaries from http://software-dl.ti.com/dsps/dsps_public_sw/sdo_tii/TI_Android_DevKit/02_00_00/index_FDS.html
> > Thanks,
> > Muthu
> > You received this message because you are subscribed to the Google Groups “Beagle Board” group.
> > To post to this group, send email to beagleboard@googlegroups.com.
> > To unsubscribe from this group, send email to beagleboard+unsubscribe@googlegroups.com.
> > For more options, visit this group at http://groups.google.com/group/beagleboard?hl=en.
> Sorry
> Victor Rodriguez
Muthu
I have a 2gb SD I go to beagleboard-rev-c4/
and execute
sudo mkmmc-android.sh /dev/sd.. and the number of my SD
and thats all
Regards
Victor
Thanks, exactly the same I am doing.
Here is my bootargs and bootcmd that I tried,
setenv bootargs ‘console=ttyS2,115200n8 androidboot.console=ttyS2 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootdelay=1 init=/init ip=off omap_vout.vid1_static_vrfb_alloc=y’
setenv bootcmd ‘mmc init 0;fatload mmc 0 80000000 uImage; bootm 80000000’
I also tried with bootargs in releasenotes, did not help.
Could you correct me if I have to make any change in bootargs ?
Thanks for helping.
Muthu
> Date: Thursday, December 2, 2010, 10:50 PM
> On Thu, Dec 2, 2010 at 12:16 PM, Muthukumar karuppiah kmkr3@yahoo.com wrote:
> > Thanks,
> > Muthu
> and execute
> sudo mkmmc-android.sh /dev/sd… and the number of my SD
> and thats all
> Regards
> Victor
> > > Thanks,
> > > Muthu
> > Sorry
> > Victor Rodriguez
this is a wild guess but try changing rootdelay=1 to rootwait
the kernel docs say:
rootwait: Wait (indefinitely) for root device to show up.
Useful for devices that are detected asynchronously
(e.g. USB and MMC devices).
rootdelay=1 waits exactly one second and then fails if the root device
doesn't exist.
if it hangs after that then maybe there are bad contacts on the card?
setenv bootargs 'console=ttyS2,115200n8 androidboot.console=ttyS2 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootdelay=1 init=/init ip=off omap_vout.vid1_static_vrfb_alloc=y'
setenv bootcmd 'mmc init 0;fatload mmc 0 80000000 uImage; bootm 80000000'
My boot args
mmc init
fatload mmc 0 0x80300000 uImage
setenv bootargs 'mem=128M androidboot.console=ttyS2 console=tty0
console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw init=/init rootwait
omapfb.video_mode=640x480MR-16@60'
bootm 0x80300000
NY the way I have a problem far from this with my beagle. Does
anyboady has been able to record on the beagle> is necessary a
preamplifier before the audio in ?
I know is not the way to ask this but make me doubt about it
Regards
Victor Rodriguez
I'm using the same TI download on my BB B5 board, the kernel stops at:
"Uncompressing Linux..........................................................
done, booting the kernel."
Nothing happened afterwards. I also tried coredruids which boots
kernel fine, but afterwards I got a static screen with "Android" shown
in the middle, nothing else and it's useless.
Anyone seen this? Or Froyo does not work on B5 at all?
Xianghua
OK I modified boot.scr to use 128M RAM instead of 256M(B5 only has
128MB), now it boots with a crappy image on screen, from serial port I
saw:
# enabling adb
adb_open
PVR_K: (FAIL) SGXInit: Incompatible HW core rev (10003) and SW core rev (10201).
# warning: `zygote' uses 32-bit capabilities (legacy support in use)
request_suspend_state: wakeup (3->0) at 40152404788 (1970-01-01
00:00:40.152374271 UTC)
init: untracked pid 799 exited
request_suspend_state: wakeup (0->0) at 45376129154 (1970-01-01
00:00:45.376098636 UTC)
init: untracked pid 911 exited
request_suspend_state: wakeup (0->0) at 50620086672 (1970-01-01
00:00:50.620086672 UTC)
init: untracked pid 932 exited
looks like TI's release does not work on B5(SGXInit fail shown above).
