It worked for me and seen the android demo but I followed exactly the
steps in the doc.
I guess you need to put into the SD the MLO and u-boot as they are
specified
for the 7" LCD.
I do not know wat they do into these but I already asked embest (no
response yet)
in the relevant forum to give us the modified x-load and u-boot
sources that
being used as they are not into the board support package.
megawatts
That is why I told you to follow the doc.
I did not go t into u-boot in order to boot the Android so no args
given there.
I loaded a SD card with the MLO and the u-boot for the Android and 7"
LCD,
from linux\demo\android
and of course the relevant uImage (4.3" or 7") into the FAT partition,
then the RFS to the ext3 partition, booted the board by pressed
the user button to boot from SD and not from flash.
It booted ok and viewed onto the 7" LCD.
Now you understand why I told you that embest has modified the x-load
(MLO) and
the u-boot (separate versions for 4.3" and 7") and not provided the
code for
these although I asked them for it. Their modified u-boot knows how to
boot
directly with the proper args into their Android image.
( I didnt check though if u-boot can be interrupted and view the
environment variables )
Ok thank you, I got it working. Follow the doc exactly and everything
should work OK. Now on to the next step, and I hope to get the source
code from the DevKit8000 team.
I am facing the similar problem what you faced in booting the demo image. Can you tell how you got it working.
what bootagrs and bootcmd you used.
which image should be copied in sdcard.
