I use BB XM rev B. I use filesystem from
> Actual link I have tried is:http://software-dl.ti.com/dsps/dsps_public_sw/sdo_tii/TI_Android_DevK…
This is my boot log:
Texas Instruments X-Loader 1.47 (Oct 23 2010 - 17:44:36)
Unsupported Chip!
Beagle xM Rev A
Starting X-loader on MMC
Reading boot sector208756 Bytes Read from MMC
Starting OS Bootloader from MMC...
Starting OS Bootloader...U-Boot 2010.06-rc1-00049-ga306f53 (Oct 23 2010 - 17:43:17)
OMAP34xx/35xx-GP ES2.0, CPU-OPP2 L3-165MHz
I2C: ready
DRAM: 256 MiB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Beagle xM Rev A
Die ID #267e00011ff00000015739eb0c037018
mmc1 is available
reading boot.scr414 bytes read
Running bootscript from mmc ...
## Executing script at 82000000
reading uImage2452580 bytes read
***** Kernel: /dev/mmcblk0p1/uImage *****
***** RootFS: /dev/mmcblk0p2 *****
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-2.6.32
Data Size: 2452516 Bytes = 2.3 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OKStarting kernel ...
Uncompressing
Linux...................................................................... .........................
Linux version 2.6.32 (a0393957@swubn01) (gcc version 4.4.0 (GCC) ) #1
Sat Oct 23 16:56:25 IST 2010
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3630/DM3730 ES1.0 (l2cache iva sgx neon isp 192mhz_clk )
SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
Reserving 4194304 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
65024
Kernel command line: console=ttyS2,115200n8 androidboot.console=ttyS2
mem=256M root=/dev/mmcblk0p2 rw rootfstype=y
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[snip boot log]
init: cannot find '/system/etc/install-recovery.sh', disabling
'flash_recovery'
# enabling adb
adb_open
warning: `zygote' uses 32-bit capabilities (legacy support in use)Switched to new clocking rate (Crystal/Core/MPU): 26.0/332/1000 MHz
its Great!There are some question:
1. Why X-loader say Unsupported Chip!
2. U-boot say DRAM: 256 MiB (why not 516?).
3. There no image on the DVI-monitor. I know about hardware difference
in revision of BBXM. Where I can download patched kernel tree, x-
loader and u-boot for Android?
You will not get any output on the DVI for the Begleboard until you
set up the right bootargs. You need something like
'omapfb.video_mode=640x480MR-16@60' to indicate that you want 640x480
output or 800x600 or 1024x768 at 60 Hz..
Add something like that to your bootargs depending on the LCD you are
using..
Regards
-- Ashwin
