angstorm build with partitions...
I got Angstorm console binaries ( MLO,x-load.bin.ift,u-boot.bin,uImage).
NAND on my beagle has been erased.
Can i proceed by copying the binaries into MMC , and boot from MMC …?
Is MMC partition is a must …? can i do without partition
Thanks & Regards,
Eshwar Rao
You can do without a partition by putting the kernel or root file system on the NAND flash. You can restore your Beagle to factory defaults using http://code.google.com/p/beagleboard/wiki/BeagleBoardDiagnostics.
