Angstrom boot - ## Error: "mmcargs" not defined
I’ve been following the instructions on http://treyweaver.blogspot.co.uk/2010/10/installing-angstrom-on-beagleboard-xm.html to get my first Angstrom sd card running.(console only)
However when I put the card into my Beagleboard Xm A2 (and I’ve also tried my Xm rev C too) and power up I get njothing on the HDMI, and on connecting to the console via serial port I get:
Texas Instruments X-Loader 1.5.0 (Jun 14 2011 - 22:04:07)
Beagle xM
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2011.03-rc1-00000-g9a3cc57-dirty (Apr 01 2011 - 17:41:42)
OMAP3630/3730-GP ES1.0, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev A
No EEPROM on expansion board
Die ID #12ea00001bf00000015739ea0703501a
reading boot.scr
** Unable to read “boot.scr” from mmc 0:1 **
reading uImage
3203088 bytes read
Booting from mmc …
Error: “mmcargs” not defined
Booting kernel from Legacy Image at 82000000 …
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3203024 Bytes = 3.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
Uncompressing Linux… … … done, booti ng the kernel.
The activity light by the SD card is still flashing but with no change on the console an hour later.
I’ve re-follwoed the steps several times, but am drawing a blank on where to look to progress this other than that I guess the mccargs error is key, but not a problem i’ve been able to find a past example of.this. Any pointers much appreciated.
Hi Nathan,
It seems that mmcargs i.e arguments that the kernel needs to be passed for booting from mmc is defined. Just type pri mmcargs and you may get the error - mmcargs not defined. Probably, mmcargs is not defined in u-boot/include/configs/omap3_beagle.h. So, the easiest way is get the latest omap3_beagle.h and replace the old one with this and recompile the u-boot.
Pradeep
