I am having issues with building the image, please help me. I feel there is problem with meta-opie cloning, kindly provide any suggestion.
Sanjeev
Here is the log -
sanjeevmg@sanjeevmg-VirtualBox:/media/ExtDrive/angstrom_bbb/setup-scripts$ MACHINE=beaglebone ./oebb.sh config beaglebone
Processing bitbake: Current branch 1.20 is up to date.
Processing meta-angstrom: Current branch angstrom-v2013.12-yocto1.5 is up to date.
Processing meta-openembedded: Current branch angstrom-staging-yocto1.5 is up to date.
Processing meta-beagleboard: Current branch dora is up to date.
Processing meta-ti: Current branch angstrom-staging-yocto1.5 is up to date.
Processing meta-ettus: Fixed to revision 5a6a642f6707dc42a5210dbbf01d2bdfd869d4b0, skipping update
Processing meta-fsl-arm: Current branch angstrom-staging-yocto1.5 is up to date.
Processing meta-fsl-arm-extra: Current branch dora is up to date.
Processing meta-nslu2: Fixed to revision bdcb4297ddb22f4eecddd4d8436cf9b6c6111922, skipping update
Processing meta-smartphone: Fixed to revision 537d0c2ab41284012e1ba79716b085a861a6812a, skipping update
layer repository name: meta-intel
layer uri: git://git.yoctoproject.org/meta-intel
layer branch/revision: dora/HEAD
Layer checkout missing at /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-intel, creating one
Cloning into ‘/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-intel’…
fatal: https://git.yoctoproject.org/meta-intel/info/refs not found: did you run git update-server-info on the server?
/media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 19: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-intel: No such file or directory
fatal: git checkout: updating paths is incompatible with switching branches.
Did you intend to checkout ‘origin/dora’ which can not be resolved as commit?
Layers present in repository:
find: `/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-intel’: No such file or directory
Processing meta-intel: /media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 75: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-intel: No such file or directory
layer repository name: meta-xilinx
layer uri: git://git.yoctoproject.org/meta-xilinx
layer branch/revision: master/21c3cd3f058d736742ebc23a7a954f23456fbea5
Layer checkout missing at /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-xilinx, creating one
Cloning into ‘/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-xilinx’…
fatal: https://git.yoctoproject.org/meta-xilinx/info/refs not found: did you run git update-server-info on the server?
/media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 19: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-xilinx: No such file or directory
fatal: Could not parse object ‘21c3cd3f058d736742ebc23a7a954f23456fbea5’.
find: `/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-xilinx’: No such file or directory
Processing meta-xilinx: /media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 79: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-xilinx: No such file or directory
Processing meta-openpandora: Fixed to revision 53ad3e60e4ed4fc7b946a2130da4bb9a8671341c, skipping update
layer repository name: meta-raspberrypi
layer uri: git://git.yoctoproject.org/meta-raspberrypi.git
Layer checkout missing at /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-raspberrypi, creating one
Cloning into ‘/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-raspberrypi’…
fatal: https://git.yoctoproject.org/meta-raspberrypi.git/info/refs not found: did you run git update-server-info on the server?
/media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 19: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-raspberrypi: No such file or directory
find: `/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-raspberrypi’: No such file or directory
Processing meta-raspberrypi: /media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 75: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-raspberrypi: No such file or directory
layer repository name: meta-handheld
layer uri: git://git.openembedded.org/meta-handheld
layer branch/revision: master/5b5e68a93aae1016f5ac1d057a721b2dbf30b8d8
Layer checkout missing at /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-handheld, creating one
Cloning into ‘/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-handheld’…
error: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none while accessing https://git.openembedded.org/meta-handheld/info/refs
fatal: HTTP request failed
/media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 19: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-handheld: No such file or directory
fatal: Could not parse object ‘5b5e68a93aae1016f5ac1d057a721b2dbf30b8d8’.
find: `/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-handheld’: No such file or directory
Processing meta-handheld: /media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 79: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-handheld: No such file or directory
layer repository name: meta-opie
layer uri: git://git.openembedded.org/meta-opie.git
layer branch/revision: master/b241408b31c2ffd941b8b38bd385136ef675a703
Layer checkout missing at /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-opie, creating one
Cloning into ‘/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-opie’…
error: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none while accessing https://git.openembedded.org/meta-opie.git/info/refs
/media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 19: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-opie: No such file or directory
fatal: Could not parse object ‘b241408b31c2ffd941b8b38bd385136ef675a703’.
find: `/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-opie’: No such file or directory
Processing meta-opie: /media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 79: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-opie: No such file or directory
Processing meta-java: Current branch dora is up to date.
Processing meta-browser: Fixed to revision fc3969f63bda343c38c40a23f746c560c4735f3e, skipping update
layer repository name: meta-mono
layer uri: git://git.yoctoproject.org/meta-mono.git
layer branch/revision: master/ac286b1682e6bcc486ceb30ef90a936949bbfeab
Layer checkout missing at /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-mono, creating one
Cloning into ‘/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-mono’…
fatal: https://git.yoctoproject.org/meta-mono.git/info/refs not found: did you run git update-server-info on the server?
/media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 19: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-mono: No such file or directory
fatal: Could not parse object ‘ac286b1682e6bcc486ceb30ef90a936949bbfeab’.
find: `/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-mono’: No such file or directory
Processing meta-mono: /media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 79: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-mono: No such file or directory
Processing meta-kde: Fixed to revision f45abfd4d87b0132a2565499392d2d49f465d847, skipping update
Processing meta-linaro: Current branch dora is up to date.
layer repository name: meta-minnow
layer uri: git://git.yoctoproject.org/meta-minnow
Layer checkout missing at /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-minnow, creating one
Cloning into ‘/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-minnow’…
fatal: https://git.yoctoproject.org/meta-minnow/info/refs not found: did you run git update-server-info on the server?
/media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 19: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-minnow: No such file or directory
find: `/media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-minnow’: No such file or directory
Processing meta-minnow: /media/ExtDrive/angstrom_bbb/setup-scripts/scripts/layerman: line 75: cd: /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-minnow: No such file or directory
Processing meta-sunxi: Fixed to revision dc663bd5d8bd873012c90da8a9f6afc49e8a0ca6, skipping update
Processing meta-qt5: Current branch dora is up to date.
Processing meta-ros: Fixed to revision 64c8b5edb221263e7fac7c03629c730ade422dff, skipping update
Processing meta-dominion: Current branch master is up to date.
Processing openembedded-core: Current branch angstrom-staging-yocto1.5 is up to date.
Setup for beaglebone completed
sanjeevmg@sanjeevmg-VirtualBox:/media/ExtDrive/angstrom_bbb/setup-scripts$ MACHINE=beaglebone ./oebb.sh update
sanjeevmg@sanjeevmg-VirtualBox:/media/ExtDrive/angstrom_bbb/setup-scripts$ MACHINE=beaglebone ./oebb.sh bitbake systemd-image
Using environment-angstrom-v2013.12 to setup needed variables. It is recommended to do ‘. environment-angstrom-v2013.12’ and run ‘bitbake something’ without using ./oebb.sh as wrapper
Executing: MACHINE=beaglebone bitbake systemd-image
ERROR: Traceback (most recent call last):
File “/media/ExtDrive/angstrom_bbb/setup-scripts/sources/bitbake/lib/bb/cookerdata.py”, line 162, in wrapped
return func(fn, *args)
File “/media/ExtDrive/angstrom_bbb/setup-scripts/sources/bitbake/lib/bb/cookerdata.py”, line 172, in parse_config_file
return bb.parse.handle(fn, data, include)
File “/media/ExtDrive/angstrom_bbb/setup-scripts/sources/bitbake/lib/bb/parse/init.py”, line 99, in handle
return h[‘handle’](fn, data, include)
File “/media/ExtDrive/angstrom_bbb/setup-scripts/sources/bitbake/lib/bb/parse/parse_py/ConfHandler.py”, line 120, in handle
abs_fn = resolve_file(fn, data)
File “/media/ExtDrive/angstrom_bbb/setup-scripts/sources/bitbake/lib/bb/parse/init.py”, line 122, in resolve_file
raise IOError(“file %s not found” % fn)
IOError: file /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-opie/conf/layer.conf not found
ERROR: Unable to parse /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-opie/conf/layer.conf: file /media/ExtDrive/angstrom_bbb/setup-scripts/sources/meta-opie/conf/layer.conf not found
sanjeevmg@sanjeevmg-VirtualBox:/media/ExtDrive/angstrom_bbb/setup-scripts$ cd sources/
sanjeevmg@sanjeevmg-VirtualBox:/media/ExtDrive/angstrom_bbb/setup-scripts/sources$ ls
bitbake meta-beagleboard meta-ettus meta-java meta-nslu2 meta-qt5 meta-sunxi
layers.txt meta-browser meta-fsl-arm meta-kde meta-openembedded meta-ros meta-ti
meta-angstrom meta-dominion meta-fsl-arm-extra meta-linaro meta-openpandora meta-smartphone openembedded-core
sanjeevmg@sanjeevmg-VirtualBox:/media/ExtDrive/angstrom_bbb/setup-scripts/sources$ cd …/
sanjeevmg@sanjeevmg-VirtualBox:/media/ExtDrive/angstrom_bbb/setup-scripts$ . environment-angstrom-v2013.12
sanjeevmg@sanjeevmg-VirtualBox:/media/ExtDrive/angstrom_bbb/setup-scripts$ bitbake beaglebone
