Angstrom demo kernel source
Does anyone know how I can just get the kernel source portion used to
do the kernel uImage build for the Angstrom demo for the Beagle
Board? I know there are instructions to download the whole
OpenEmbedded distribution and use bitbake to do the build but I'm
running out of hard drive space (<4GB) on my vmware guest Fedora box =
( and the distribution requires 10GB minimum. I just need the kernel
source.
The last couple days, I wasn't able to get audio to work properly on
the Beagle Board using the latest different GIT distributions out
there. Thanks to Arun, I was able to grab the kernel source (2.6.29-
rc2) from the official linux-omap distribution and applied Steve
Sakoman's "ASoC: Complete Beagleboard support" patch to get audio
support. It built and loaded fine on my Beagle Board but I wasn't
able to get audio working; I just playing a simple wav file and got
the following:
[root@OMAP3EVM /root]# aplay test.wav
Playing WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 8000 Hz,
Stereo
aplay: pcm_write:1266: write error: Input/output error
Since audio is working with the Angstrom demo, I would like to get its
kernel source; I need it for development, especially trying to get
TI's open source DSP/BIOS DSPLINK driver to compile with it. Thanks.
Andy
http://cgit.openembedded.net/cgit.cgi?url=openembedded/tree/packages/linux/linux-omap_git.bb&id=6a6d6bab519aefb44e3d49d305134057adf7539e
You can browse the OE repository online.
Philip
Openembedded-Hotels, Villen, Unterkünfte in Leipzig
Philip
Philip,
Thanks for the link. I noticed from the bb file that it's using the
latest l-o git tree for the baseline and then applying the following
patches:
file://no-empty-flash-warnings.patch;patch=1 \
file://no-cortex-deadlock.patch;patch=1 \
file://read_die_ids.patch;patch=1 \
file://fix-install.patch;patch=1 \
file://musb-support-high-bandwidth.patch.eml;patch=1 \
file://mru-fix-timings.diff;patch=1 \
file://mru-fix-display-panning.diff;patch=1 \
file://mru-improve-pixclock-config.diff;patch=1 \
file://mru-make-video-timings-selectable.diff;patch=1 \
file://mru-enable-overlay-optimalization.diff;patch=1 \
file://0001-Removed-resolution-check-that-prevents-scaling-when.patch;patch=1
file://0001-Implement-downsampling-with-debugs.patch;patch=1 \
file://0001-DSS-New-display-subsystem-driver-for-OMAP2-3.patch;patch=1
file://0002-DSS-OMAPFB-fb-driver-for-new-display-subsystem.patch;patch=1
file://0003-DSS-Add-generic-DVI-panel.patch;patch=1 \
file://0004-DSS-support-for-Beagle-Board.patch;patch=1 \
file://0005-DSS-Sharp-LS037V7DW01-LCD-Panel-driver.patch;patch=1 \
file://0006-DSS-Support-for-OMAP3-SDP-board.patch;patch=1 \
file://0007-DSS-Support-for-OMAP3-EVM-board.patch;patch=1 \
file://0008-DSS-Hacked-N810-support.patch;patch=1 \
file://0009-DSS-OMAPFB-allocate-fbmem-only-for-fb0-or-if-spes.patch;patch=1
file://0010-DSS-OMAPFB-remove-extra-omapfb_setup_overlay-call.patch;patch=1
file://0011-DSS-OMAPFB-fix-GFX_SYNC-to-be-compatible-with-DSS1.patch;patch=1
file://0012-DSS-Add-comments-to-FAKE_VSYNC-to-make-things-more.patch;patch=1
file://0013-DSS-OMAPFB-remove-extra-spaces.patch;patch=1 \
file://0014-DSS-fix-clk_get_usecount.patch;patch=1 \
file://0001-This-merges-Steve-Kipisz-USB-EHCI-support.-He-star.patch;patch=1
file://0001-board-omap3beagle-set-i2c-3-to-100kHz.patch;patch=1 \
I want to download those patches; do you know where they are located
on that OE online repository? Thanks.
Andy
look in packages/linux/linux-omap-git.
Philip
Andy
Never mind, I found them:
http://cgit.openembedded.net/cgit.cgi?url=openembedded/tree/packages/linux/linux-omap2-git/beagleboard&id=6a6d6bab519aefb44e3d49d305134057adf7539e
Thanks.
Andy
