Angstrom gpe do not load correctly after login
I am using the BeagleBoard C2. With Linux 2.6.28 and the Angstrom
2009.x-test-20090305.
Is have set the resolution to 800x600 using the command ling args
setenv bootargs console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw
rootdelay=1 omapfb.video_mode=800x600MR-24@60 mmcinit;fatload mmc 0
80000000 uimage;bootm 80000000;
This loads okays and I get the command line. On my DVI monitor I get
the GPE login screen.
After login the screen goes blank and I get the X cursor for about
5seconds before the screen returns back to the GPE login.
I have tried different resolutions with no luck.
I have checked Xorg.0.log and there are some error lines but I cannot
find anything on the web about them.
Anybody any ideas?
Here are the xorg logfile details.
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/beagleboard:0
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for
inet6
(WW) Failed to open protocol names file /usr/lib/xorg/protocol.txt
X.Org X Server 1.5.3
Release Date: 5 November 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.25.6 x86_64
Current Operating System: Linux beagleboard 2.6.28-omap1 #1 Tue Mar 24
18:57:27
CET 2009 armv7l
Build Date: 16 April 2009 09:44:57AM
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon May 4 05:08:54 2009
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Builtin Default Layout"
(**) |-->Screen "Builtin Default fbdev Screen 0" (0)
(**) | |-->Monitor "Builtin Default Monitor"
(**) | |-->Device "Builtin Default fbdev Device 0"
(==) Automatically adding devices
(==) Automatically enabling devices
(==) No FontPath specified. Using compiled-in default.
(==) FontPath set to:
        /usr/share/fonts/X11/misc
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Cannot locate a core pointer device.
(II) Cannot locate a core keyboard device.
(II) The server relies on HAL to provide the list of input devices.
        If no devices become available, reconfigure HAL or disable
AllowEmptyInp
ut.
(II) Loader magic: 0x17fb00
(II) Module ABI versions:
        X.Org ANSI C Emulation: 0.4
        X.Org Video Driver: 4.1
        X.Org XInput driver : 2.1
        X.Org Server Extension : 1.1
        X.Org Font Renderer : 0.6
(II) Loader running on linux
(--) using VT number 3
(II) System resource ranges:
(II) "extmod" will be loaded. This was enabled by default and also
specified in
the config file.
(II) "dbe" will be loaded. This was enabled by default and also
specified in the
config file.
(II) "glx" will be loaded. This was enabled by default and also
specified in the
config file.
(II) "freetype" will be loaded. This was enabled by default and also
specified i
n the config file.
(II) "dri" will be loaded. This was enabled by default and also
specified in the
config file.
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
        compiled for 1.5.3, module version = 1.0.0
        Module class: X.Org Server Extension
        ABI class: X.Org Server Extension, version 1.1
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(WW) Warning, couldn't open module glx
(II) UnloadModule: "glx"
(EE) Failed to load module "glx" (module does not exist, 0)
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts//libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT
Project"
        compiled for 1.5.3, module version = 2.1.0
        Module class: X.Org Font Renderer
        ABI class: X.Org Font Renderer, version 0.6
(II) Loading font FreeType
(II) LoadModule: "type1"
(WW) Warning, couldn't open module type1
(II) UnloadModule: "type1"
(EE) Failed to load module "type1" (module does not exist, 0)
(II) LoadModule: "record"
(WW) Warning, couldn't open module record
(II) UnloadModule: "record"
(EE) Failed to load module "record" (module does not exist, 0)
(II) LoadModule: "dri"
(WW) Warning, couldn't open module dri
(II) UnloadModule: "dri"
(EE) Failed to load module "dri" (module does not exist, 0)
(II) LoadModule: "omapfb"
(II) Loading /usr/lib/xorg/modules/drivers//omapfb_drv.so
(II) Module omapfb: vendor="X.Org Foundation"
        compiled for 1.5.3, module version = 0.0.1
        ABI class: X.Org Video Driver, version 4.1
(II) omapfb: Driver for OMAP framebuffer (omapfb) and external LCD
controllers:
        omap1/2/3, S1D13745, HWA742
(WW) Falling back to old probe method for OMAPFB
(II) Running in FRAMEBUFFER Mode
(WW) Error opening /sys/devices/platform/omapfb/ctrl/name: No such
file or direc
tory
(WW) Can't autodetect LCD controller, assuming internal
(II) LCD controller: internal
(II) omapfb(0): VideoRAM: 1876KiB (SDRAM)
(II) omapfb(0): Creating default Display subsection in Screen section
        "Builtin Default fbdev Screen 0" for depth/fbbpp 24/32
(--) omapfb(0): Depth 24, (==) framebuffer bpp 32
(==) omapfb(0): RGB weight 888
(==) omapfb(0): Default visual is TrueColor
(--) omapfb(0): Virtual size is 800x600 (pitch 800)
(**) omapfb(0): Built-in mode "current"
(==) omapfb(0): DPI set to (96, 96)
(--) Depth 24 pixmap format is 32 bpp
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
        ABI class: X.Org ANSI C Emulation, version 0.4
(EE) omapfb(0): FBIOBLANK: Invalid argument
(II) omapfb(0): DPMS enabled
(II) omapfb(0): Video plane capabilities:
(II) omapfb(0): Video plane supports the following image formats:
        CLUT_4BPP
        CLUT_2BPP
        CLUT_1BPP
        RGB444
        YUY422
(II) omapfb(0): XVideo extension initialized
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(NI) OMAPFBSaveScreen: Dim backlight?
(II) config/hal: Adding input device HID 046a:0001
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input//evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
        Module class: X.Org XInput Driver
        ABI class: X.Org XInput driver, version 2.1
(**) HID 046a:0001: always reports core events
(**) HID 046a:0001: Device: "/dev/input/event3"
(II) HID 046a:0001: Found keys
(II) HID 046a:0001: Configuring as keyboard
(II) XINPUT: Adding extended input device "HID 046a:0001" (type:
KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) HID 046a:0001: xkb_rules: "evdev"
(**) Option "xkb_model" "evdev"
(**) HID 046a:0001: xkb_model: "evdev"
(**) Option "xkb_layout" "us"
(**) HID 046a:0001: xkb_layout: "us"
(II) config/hal: Adding input device Microsoft Microsoft Trackball
Optical?
(**) Microsoft Microsoft Trackball Optical?: always reports core
events
(**) Microsoft Microsoft Trackball Optical?: Device: "/dev/input/
event2"
(II) Microsoft Microsoft Trackball Optical?: Found 5 mouse buttons
(II) Microsoft Microsoft Trackball Optical?: Found x and y relative
axes
(II) Microsoft Microsoft Trackball Optical?: Configuring as mouse
(**) Microsoft Microsoft Trackball Optical?: YAxisMapping: buttons 4
and 5
(**) Microsoft Microsoft Trackball Optical?: EmulateWheelButton: 4,
EmulateWheel
Inertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "Microsoft Microsoft
Trackball Optical
?" (type: MOUSE)
Hi All,
I found that loading the latest Angstrom demo version worked. Its was
easier than it looked.
Melvin.
Hi Melvin,
  I am glad you got it working. The symptom you described first is
common
with late unstable Angstrom and sometimes those marked as stable. I
have seen it more than once on different releases.
BTW: after 2.6.28, omapfb.video_mode=800x600MR-24@60 is changed to
dvimode=800x600MR-24@60
    Not being a linux.embeded/beagleGuts guru I look for the simple
solution.
enjoy,
Don Lewis
Hi All,
Playing with the resolution on the BeagleBoard Angstrom demo. Kernal
2.6.29.
Tried changing the bootargs by quitting autoboot and entering
setenv mmcargs setenv bootargs console=ttyS2,115200n8 vram=12M
dvimode=800x600MR-24@60 omapfb.debug=y omapdss.def_disp=dvi root=/dev/
mmcblk0p2 rw rootfstype=ext3 rootwait
Then typing #boot
It appears Angstrom still uses the low resolution 640 x 480. I can
confirm this using the linux command fbset shows
root@beagleboard:~# fbset
mode "640x480-59"
    # D: 23.500 MHz, H: 29.375 kHz, V: 59.464 Hz
    geometry 640 480 640 480 32
    timings 42553 48 80 3 7 32 4
    rgba 8/16,8/8,8/0,0/0
endmode
My printenv is
OMAP3 beagleboard.org # printenv
bootcmd=if mmc init; then if run loadbootscript; then run bootscript;
else if ru
n loaduimage; then run mmcboot; else run nandboot; fi; fi; else run
nandboot; fi
bootdelay=10
baudrate=115200
loadaddr=0x82000000
vram=12M
dvimode=1024x768MR-16@60
defaultdisplay=dvi
nandargs=setenv bootargs console=${console} vram=${vram}
omapfb.mode=dvi:${dvimo
de} omapfb.debug=y omapdss.def_disp=${defaultdisplay} root=/dev/
mtdblock4 rw roo
tfstype=jffs2
loadbootscript=fatload mmc 0 ${loadaddr} boot.scr
bootscript=echo Running bootscript from mmc ...; source ${loadaddr}
loaduimage=fatload mmc 0 ${loadaddr} uImage
mmcboot=echo Booting from mmc ...; run mmcargs; bootm ${loadaddr}
nandboot=echo Booting from nand ...; run nandargs; nand read $
{loadaddr} 280000
400000; bootm ${loadaddr}
stdin=serial
stdout=serial
stderr=serial
dieid#=38de00030000000004013f790301701d
bootargs=console=ttyS2,115200n8 vram=12M dvimode=800x600MR-24@60
omapfb.debug=y
mmcargs=setenv bootargs console=ttyS2,115200n8 vram=12M
omapfb.debug=y omapdss.def_disp=dvi root=/dev/mmcblk0p2 rw
ait
I get the message during linux boot:
Kernel command line: console=ttyS2,115200n8 vram=12M
Unknown boot option `omapdss.def_disp=dvi': ignoring
But I do not think this would affect the resolution.
Any ideas?
cheers.
