Hi all,
I wanted to know if the Beagleboard of the shelf, has Ångström GUI in
it. My BB gives the login in command line.
Is there a command to enable GUI? or should get a different
distribution of Ångström?
Hi all,
it. My BB gives the login in command line.Is there a command to enable GUI? or should get a different
If you follow the link below, you can use a web tool to build a custom
Angstrom distro complete with window manager (make sure you select X11
in the User Environment screen).
Tim
