Greetings.
After SSH’ing into the board when the default angstrom boot is loaded on I cannot seem to do anything. I’m trying to load python and get into what I consider to be the “Idle” IDE. I understand python but linux is still pretty cryptic to me. Anyone written a noob guide?
Bill
Greetings,
Greetings.
After SSH'ing into the board when the default angstrom boot is loaded on I
cannot seem to do anything. I'm trying to load python and get into what I
consider to be the "Idle" IDE. I understand python but linux is still
After you SSH in to your BBB, type the command:
which python
If Python is already installed (which I believe it is by default), you should see the directory path to the Python executable/interpreter. If python is not installed, it will simply return you to the shell prompt.
--- Jay Nugent WB8TKL
Instructor, UNIX/Linux System Administration
Washtenaw Community College
