Angstrom - How to be root user via minicom?
Hi guys,
I'm having difficulty executing my hello world! program on Angstrom
via the minicom.
I can execute it using the root shell in Angstrom when I have it
connected to my monitor but when I try to run it via minicom it says I
do not have permission.
In Ubuntu to be root user I have to use sudo, but this is obviously
not true in Angstrom.
Any tips would be good. Thanks you for your time.
Rob
via the serial link you can log as root (no passwd)
I don’t know if sudo is installed by default on angstrom.
cheers,
Maxime
I don't know if sudo is installed by default on angstrom.
ok thanks Maxime I will give it a go login in with no password. I take
it no username also?
Thanks for your time,
Rob
Ha! It works. ok I just use 'root' as the username and no password.
Excellent.
