angstrom image
I can’t find a working angstrom image file to flash on my beaglebone , every image I downloaded didn’t work well
I am not too sure its supported anymore
try a REAL OS and use Debian.
Not exactly the most helpful reply. :wink:
Mahmoud, you didn’t specify what device you are using. The most up-to-date Debian images are published by Robert C Nelson. You can find them here:
https://rcn-ee.com/rootfs/
If you’re just starting out, I have some instructions I’ve been putting together for BBB/BBG as well as for the newer BBGW:
https://www.ccoderun.ca/programming/2015-06-07_BeagleBoneBlack/index.html
https://www.ccoderun.ca/programming/2016-06-29_BBGW/index.html
Stéphane
Everything one needs is right here: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
Including links to the latest images.
